Old 03-23-2016, 05:11 PM   #1
1968 26' Overlander
Portland , Oregon
Removing Grote Reflectors - How the Heck?
How can I remove my Grote reflectors for polishing. They rotate so the don't seem to be adhered but there is now visible way to remove the plastic reflector from the aluminum body, which I assume is riveted on? Thanks!
ID:	259259   Click image for larger version
www.airstreampdx.com
My 1968 Overlander restoration thread https://www.airforums.com/forums/f44/...os-146457.html
AirstreamPDX is offline   Reply With Quote
Old 03-23-2016, 05:26 PM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Pretty sure they have one rivet holding them on.
desertair27 is offline   Reply With Quote
Old 03-23-2016, 06:44 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
You have to pry the plastic out of the aluminum frame then there is one rivet in the center.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Original Argosy MH reflectors? ViewRVs Argosy Motorhomes 6 01-27-2013 09:37 AM
sew heat reflectors for windows CampUnger General Repair Forum 9 04-16-2012 01:45 PM
Round red rear reflectors hampstead38 Lights - Interior & Exterior 4 04-13-2010 09:37 AM
Removing REFLECTORS??? fly2havefun Exterior Restoration Forum 11 02-16-2009 07:27 PM
Grote Marker lights C Johnson 1956 - 1965 Caravel 6 12-15-2008 04:44 PM
