Old 10-02-2016, 06:42 PM   #1
1968 26' Overlander
Edmonton , Alberta
Introduction Newbie 1968 Airstream International Overlander
Hi everyone, I just picked up this beauty and had some question regarding how many feet of window stripping I need to replace all the seals. I don't have calipers but maybe someone can answer if the glass was 1/8" or 3/32" so I can order clips, I will measure to make sure I order the right ones though. last question cabinet latches and white cabinet latches available? and does anyone make the trim that goes on the body I think it is blue in photos and it's a rectangle. Thank you in advance! I'm sure I will be asking a lot of questions in the future.
Ken in Canada
ID:	272741   Click image for larger version
ID:	272743   Click image for larger version
chaostheory is offline   Reply With Quote
Old 10-02-2016, 06:44 PM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
Beautiful trailer! That was the year I was born!
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-02-2016, 07:07 PM   #3
New Borockton , Alabama
Images: 21
Wow! Very nice
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 10-02-2016, 07:38 PM   #4
1968 22' Safari
NorCal , California
Beauty!
We just had a '68 Safari follow us home. Last week I replaced all of the window seals.
You can get it at Vintage Trailer Supply.
The cabinet latches are available from Inland RV
White
Brown
As I understand (and I'm new too so I could be wrong) some glass has metal trim, some does not. Mine has both. The window to the right of the door has metal as does the kitchen but the others windows do not. I ordered both size clips from VTS to see which would fit best.
I used a plastic scraper to remove the old window gasket and CRC Gasket remover (on one window with a different type of old gasket I used brake cleaner as the old adhesive was a little stubborn). I used my Dremel with these 'buffs' that are like Scotchbrite pad material, to clean up the aluminum and then wiped the surface down with rubbing alcohol before applying 3M Weatherstripping adhesive and the weather stripping.
Let me know if you want photos.
Gratitude for all there is and all there isn't!
Photos of our gal.
WBCCI #19233
EmptyNesters is offline   Reply With Quote
Old 10-02-2016, 07:44 PM   #5
1968 22' Safari
NorCal , California
Oh, I forgot to say that all of the latches in our rig are brown and some were faded so while applying 'Restor-A-Finish' to the wood, I thought I'd see what would happen if I put some on the latches. It helped a lot and now I don't think I'll replace them as they look much better, though not perfect.
(Right side is 'before', left is 'after')
Photos of our gal.
WBCCI #19233
Old 10-03-2016, 11:23 AM   #6
kdickinson's Avatar
Taos , New Mexico
What a nice trailer - enjoy! My 69 needs the seals replaced on windows and roof vents but I just have not gotten around to it.
kdickinson is offline   Reply With Quote
Old 10-03-2016, 01:35 PM   #7
GumbyGirl's Avatar
1970 27' Overlander
Brookings , Oregon
Originally Posted by EmptyNesters View Post
Beauty!
How many feet of seal "stuff" did you use? We are getting ready to start that as well.
Cathy
GumbyGirl is offline   Reply With Quote
Old 10-03-2016, 02:03 PM   #8
1968 22' Safari
NorCal , California
I used between 37 and 39 feet for my 6 windows. I ordered a roll of both sizes from VTS but only ended up using the portion from the 50' roll. I'll hang on to the other for future use.
I think my Safari uses a different kind than the 1970's.
Photos of our gal.
WBCCI #19233
Old 10-03-2016, 02:38 PM   #9
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Very nice 68, I'm just a little partial to them myself!!
If the glass is original it should be 1/8 but check to be sure. I put a little dab of clear silicone inside the bottom of each clip to help keep them in place. If a new clip is too loose, take it off the glass and give it a gentle squeeze with pliers and slide it back on the glass. Ditto the dremel with scotchbrite buffs for getting the adhesive residue off the window frame, by far the best and fastest method I found to clean the frame. Some places suggest using weather strip adhesive on the new gaskets. I just cleaned the frame really well,wiped with acetone or lacquer thinner and then applied my new gaskets using just the peel and stick adhesive on them. No problems in 7 years. Do take time when you miter the bottom corners and get the fit perfect or it can be a spot for a leak (sure don't need to create any as the old 68's have plenty of leaks on their own-ha). I used new single edge razor blades cutting straight down on a piece of wood to make the miters. That method gave me the cleanest cut and the tightest fit. Put a very little dab of black windshield silicone in the joint and it will be good to go and never leak.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-03-2016, 08:41 PM   #10
1968 26' Overlander
Edmonton , Alberta
Thanks for the information! How do I order from Inland RV? I assume I have to call in my order? can't just click and check out. I'm in Canada so the dollar is going to hurt me and shipping.
Beauty!
White
Brown
Old 10-04-2016, 08:00 AM   #11
1968 22' Safari
NorCal , California
I believe you will have to call or fill in their 'Contact Us' form on their web site.
http://www.inlandrv.com/contact/
Photos of our gal.
WBCCI #19233
Old 10-05-2016, 09:08 PM   #12
1968 26' Overlander
Edmonton , Alberta
I gave them a call ordered 4 latches... Ouch with the conversion and shipping to Canada was a bit pricey, but I will have complete latches. Ordered the clips and 50' of seal I should be good to go. Thanks!!!
Old 10-05-2016, 09:44 PM   #13
1968 22' Safari
NorCal , California
They're spendy that's for sure. That's why I decided to live with my faded latches. They do look a bit better with the wood treatment on them. Good enough to leave them for now while I tackle more expensive repairs.
I spent today installing all new screen material and a mini blind in the galley. I ordered the screen spline from Vintage Trailer supply but it was the wrong size for my screens so I took a chance at our tiny little town hardware store and found the correct size. Go figure!
Thanks to Aluminuminum for his idea of the miniblinds. I love the new look. Very clean.
before and after
ID:	272947   Click image for larger version
Photos of our gal.
WBCCI #19233
Old 10-13-2016, 10:40 PM   #14
1968 26' Overlander
Edmonton , Alberta
I like the look, how will they travel?
before and after
Old 10-14-2016, 07:34 AM   #15
1968 22' Safari
NorCal , California
We haven't had our girl on the road since I installed them but you can read more on them on Aluminuminum's thread.
http://www.airforums.com/forums/f454...nt-111812.html
I understand his are attached to the screen with screws, AirstreamPDX attached his with 3M tape and I used velcro tape with 10# test.
Photos of AirstreamPDX's install can be found here - this is not my idea, I'm simply standing on the shoulders of creative Airstreamers before me.
Save
Photos of our gal.
WBCCI #19233
Old 10-15-2016, 06:10 AM   #16
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
Chaos,
Welcome to the forums. We're just finishing our 68 Overlander (not that you ever really finish). Ours is a twin (26T) from California, so a little different floor plan than yours. We've spent about 20 nights in ours so far and hope you enjoy yours as much as we are enjoying ours.
If interested, there are some more details at "The Shiney Reveal 1968 Overlander". I still haven't figured out how to use a direct link to the thread... I'll try this:
http://www.airforums.com/forums/f394...er-155180.html
Roy and Marie
64airstream is offline   Reply With Quote
1968, 1968 airstream
new owner introduction: 68 Overlander International in Europe tony hunt 1965 - 1969 Overlander 4 04-24-2016 01:39 PM
Newbie Introduction from Kirkland, WA ResoRon Member Introductions 2 08-12-2012 11:32 AM
Sorta Newbie Introduction dxlyj 1970 - 1973 Sovereign 11 10-27-2011 04:10 AM
Newbie Introduction and a Question rasmuw 1959-69 Tradewind 10 07-26-2007 09:53 AM
newbie - introduction - jhelion jhelion Member Introductions 5 07-30-2006 07:59 PM
