07-06-2015, 05:36 PM
26 CR 353
, New York
How do I read this propane gauge?
My propane hookup has what looks like a gauge. Any idea how to read it?
Also, why does this forum rotate my images?
07-06-2015, 05:49 PM
2012 27' Flying Cloud
W
, New England
Hi.
I've never seen that before but would imagine the location of the top of that black line with the stamped stripe is telling you you're getting low - if it hits that bottom one, you're out of propane. Have you ever seen it with a freshly filled tank? I bet the black line goes to the top of that little slot there....
As to rotation, I think that's an Apple thing?
07-06-2015, 06:07 PM
Biloxi
, Mississippi
Try downsizing and cropping your photo. That works for me when using my iPad.
MICHAEL
07-06-2015, 09:23 PM
1999 34' Excella
Hillsboro
on iphone, keep the big button to the right, the glass display facing you, the volume buttons facing down.... usually will post 'properly'... it's like it wants to 'orient' pics in the 'landscape' format.. Also, resize/crop will remove that setting.
Peace and Blessings..
Channing
WBCCI# 30676
07-07-2015, 12:57 PM
2012 23' FB International
Woodstock
, Ontario
It looks like a mechanical gauge that is connected to a float inside the tank. We used to have something similar on our lift trucks to warn the driver he was running low on fuel.
JCW
07-07-2015, 02:19 PM
Princeton
, New Jersey
If that gauge is on the transfer switch between your 2 tanks, and I think that is what it is, it will show you when the tank it is pointing to is empty.
If both tanks are open as the one online empties the indicator will pop up and the second tank will automatically come on line. This gives you ample warning to fill the original tank before running out of propane completely.
2004 Excursion 4x4
07-07-2015, 04:11 PM
26 CR 353
, New York
Here is context. Its between the airstream and a pressure regulator:
07-07-2015, 04:38 PM
Princeton
, New Jersey
Lets see a picture of the top of the regulator to see if there is a gauge there. It looks like that is a switching regulator per the arrow on the face of the knob.
At this point i have no idea what that thing is between the regulator and the trailer. You may have to visit a propane dealer for a quick answer.
Ask if it could be a high flow safety shut off if the diaphragm in the regulator fails.
2004 Excursion 4x4
07-07-2015, 06:13 PM
26 CR 353
, New York
Here is the whole propane system:
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
OPD valves with wire to propane gauge
eubank |
LP Gas, Piping, Tanks & Regulators |
2 |
09-29-2008 02:59 PM |
Propane gauge
nazz300 |
36 |
05-03-2007 08:13 AM |
OPD valve with Remote Read Gauge
68 Overlander |
13 |
04-07-2006 10:08 PM |
Ordering tanks - remote read gauge?
ClassicRides |
3 |
01-04-2005 06:56 PM |
Propane tank gauge
Jim Miller |
6 |
04-09-2003 04:25 PM |
