Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 12-14-2002, 10:00 PM   #1
garp
Profile:
Question Zolotone Removal
I would like to remove the Zolotone paint from the interior walls of my '64 Bambi II. The walls are aluminum and the paint is not looking too good. I like the look of polished interiors but need some help getting started removing the existing paint. Any suggestions?
garp is offline   Reply With Quote
Old 12-14-2002, 10:23 PM   #2
oldvws
Profile:
can you use an electrc heat gun (high power hair dryer) ?
oldvws is offline   Reply With Quote
Old 12-14-2002, 11:07 PM   #3
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Zolatone is actually a paint-like product...I don't think a heat gun will do anything to remove it. That would work better on a vinyl wallcovering...
Here is a link to a post in Tom Patterson's VAC Archive that describes one person's Zolatone removal method. Personally, it sounds like way too much work for me! I'd re-Zolatone over the old.
You may also want to contact the Zolatone manufacturer to see if they recommend a particular stripper. Here's another link, this one to the Zolatone website to find a distributor in your area who could probably help.
Good luck in whatever you decide to do ~
Shari
Old 12-15-2002, 08:17 AM   #4
garp
Profile:
Thanks Shari, I checked out Tom Patterson's link and will try some experimenting. I wrote to Zolatone about 6 months ago but never heard back. I figure they don't want to encourage people to remove their product
Old 12-15-2002, 12:55 PM   #5
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Stripping Zolotone
The only product we found to do any kind of damage to Zolotone was a product called Aircraft Stripper. It is NASTY stuff. Comes in gallon cans and clearly states that it doesn't meet federal regualtions. Took two applications of stripper to take off the Zolotone. This stuff is so nasty, that you are to squeeze a lemon or lime in your eye if you get it in one of them. Wear long sleeves, goggles, a hat and long thick rubber gloves. We found the stripper at a place that caters to the automotive finishers in south Phoenix.
After removing the Zolotone in the front, we found that the interior would be way too busy, looked like a funhouse mirror. So we ended up painting after all. Check out the picture. That's without polishing.
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 12-15-2002, 01:01 PM   #6
flyfshr
ModeratorMan
flyfshr's Avatar
Phoenix , Arizona
Oh, one more thing...
The installers at the factory scribed in the interior aluminum panels to indicate where to put rivets in to the vertical frame members. The scribe went the whole width of the panels in most places between the trailer's endcaps. Guess they figured the Zolotone would hide it, which it did. Seems to be too deep to buff out. Something to consider if you want to polish the interior. Also, make sure you have aluminum endcaps and not the one-piece plastic ones. They won't buff up too well
WBCCI/VAC #2699
Air #10
Old 12-15-2002, 01:58 PM   #7
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
flyfshr ~
I know what you mean about the Aircraft Stripper! I used it to strip our outside clearcoat...nasty stuff, but it worked! I thought it might work on Zolatone, but wasn't sure, as I kept my Zolatone intact...thanks for the clarification.
Shari
BTW 'garp' ~ Our '64 has the plastic end caps...yours, probably does too.
Old 12-15-2002, 02:09 PM   #8
flyfshr
ModeratorMan
flyfshr's Avatar
Phoenix , Arizona
End Caps
Shari ~
We have the aluminum end caps, clearly seen in the above photo. I insisted on metal as the plastic would become brittle in our lovely summers and I didn't want ot have to replace one
WBCCI/VAC #2699
Air #10
Old 12-15-2002, 02:21 PM   #9
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
flyfshr ~
It's clear that your end caps are aluminum...my comment regarding ours being plastic was more for 'garp' as his is a '64 like Maxwell. Anyway, good thinking with the AZ heat the aluminum is probably a better choice for you. I do like the look of the aluminum panels (better than the plastic) with all the rivets...but I'd still leave it Zolatone'd.
Do you know what year A/S switched from aluminum to plastic? I'm thinking it was probably '64 when they went from 7 to 5 panels on the exterior...anybody???
Shari
Old 12-16-2002, 12:51 PM   #10
flyfshr
ModeratorMan
flyfshr's Avatar
Phoenix , Arizona
Aircraft Remover
Found a picture of the can. Be forewarned...this stuff is nasty.
WBCCI/VAC #2699
Air #10
Old 12-16-2002, 02:41 PM   #11
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Aircraft stripper
We use the aircraft stripper on the aluminum wings of our Schweizer 2-33 gliders on paint that has been baked on by 15 to 20 years of Texas sun. It does the job, but it is truly nasty to work with.
I wear heavy rubber gloves meant for handling corrosive liquids and either goggles or a face shield. I also wear old clothes with long sleeves and just throw them away when I'm finished.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 02:31 PM
plastic beads for clearcoat removal? john hd Cleaning, Stripping & Polishing 22 04-20-2008 11:30 AM
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 09:15 AM
Zolotone? Lana 1966 - 1968 Safari 4 01-17-2003 05:08 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 02:22 PM
