I worked hard to clean the interior walls of my 1972 Land Yacht. They look pretty good but I would really like to freshen them up with Zolatone.
I discovered the stuff is really expensive. Is there a primer I could use istead of Zolatone brand, or better yet could I get away with not using primer at all?
I plan on spraying the whole interior with it, front cap walls and rear plastic bathroom cap. Any insight or warnings?
I'm not sure which year Airstream switched over from Zolotone to vinyl clad interior walls, but doesn't a '72 have vinyl? Did you strip the vinyl off or are you planning on using Zolotone over the vinyl? I would think it would make a big difference in what primer you would use...
Regardless, I would stick with the Zolotone manufacturers recommendation for primer. It would be a waste to spend the extra money on the Zolotone now, only to have the primer fail in a couple years and have to re-do it all, don't you think?
Yes the walls are Vinyl clad. I cleaned them up but they still look dingy. I think you are right about spending a little more now on the correct primer.
I was planning on painting the Zolatone over the vinyl.
I haven't considered stripping the vinyl off. . Is it difficult to do?
Our trailer is a '64 & we have the original Zolotone so I don't know how difficult it would be to strip the vinyl. Obviously, it's going to be a lot more effort to strip the vinyl than not.
My main comment regarding going over the vinyl would be to make sure the vinyl is securely attached everywhere...no curling, bubbles, tears or lose edges etc. Remember Zolotone is technically, just a texturized, multi-color spray paint...the vinyl texture (not color, but texture) will probably still read through and the end result will depend on the substrate it is appled to.
I've seen Zolotone used over vinyl wallcovering in commercial applications before with great success, however I would strongly encourage you to follow all the manufacturer's recommendations for such an application.
Good luck...keep us posted on what you decide to do ~
Painting over the vinylclad is not that difficult, provided you prep the material properly.
First, the material "MUST" be thoroughly cleaned.
Second, you must cut into the vinyl material with 120 grit sandpaper, until much of the original appearance is gone.
Lightly scuffing it WILL NOT WORK.
The kind or type primer to use, now depends on what final finish you wish to use.
Removing the vinyclad from the metal is not hard, but, only if you can walk on water. If you can't, then don't even try. You will be sorry, for the next two lifetimes.
Hi,
The vinyl covering in my airstream has delaminated in some places, been torn in others and is missing from the underside of the overhead in the bunk area. I have decided to keep it because it matches the tambour door and I have fallen in love with the airstream as it is. Anyway, is there any available vinyl anywhere from 1977?
--andrea
Andrea.
All the "vinyl clad" aluminums have been discontinued by Airstream, some 3 or 4 years ago.
You can cover the interior with materials such as "Ozite."
However, an exact installation, with "ALL" the proper materials and adhesives, is a "must."
inlandrv.com
airstreamparts.com
airstreamcandy.com
When I first purchased the '71, the interior was discolored, front and rear plastic sections yellowed from age. Throughly cleaned the wall sections, sanded lightly only the plastic parts and used semi gloss and a small foam roller to paint all of it. The result was fantastic. Gave the interior a 'new' look. The semi gloss kept the original sheen and is very durable.
Have changed the color twice since the first initial painting and the original graining of the walls is still perfectly visible. Helps to seal some of the rivets and seams too!
Inland Andy says;"Removing the vinyclad from the metal is not hard, but, only if you can walk on water. If you can't, then don't even try. You will be sorry, for the next two lifetimes."
_____Andy____
However the venerable airstreamcaravel postulates:
"I would bet that ACETONE would remove it! OR any of the specific adhesive removers like GOO GONE would be worth a try....... Clear as Mud now?"
___DMC___(Airstreamcaravel)
There is a member whose husband has sea-legs (apparently). i.e. he apparently can walk on water (in her eyes anyway) follow links below: Links to vinyl stripping: (vinylclad,vinyl removal,vinyl walls, etc) http://www.airforums.com/forum...&threadid=2625
I wish the lady Anna would post some pictures. and that Airstreamcaravel in Chicago who vows that acetone works and is willing to bet money on it...but no proof that I have seen.
So again nothing settled, yes dude it IS as clear as mud! I will eventually see for myself, but this seems to be a recurring question on all the forums.
As I have said before..."it's prob'ly not impossible but I'll bet it is dammed hard! I'm hopin' though that Andy and I are wrong and Anna & Chicago are right on)! Cause I want the stuff off my walls too.
Originally posted by FLguy8 When I first purchased the '71, the interior was discolored, front and rear plastic sections yellowed from age. Throughly cleaned the wall sections, sanded lightly only the plastic parts and used semi gloss and a small foam roller to paint all of it. The result was fantastic. Gave the interior a 'new' look
Paint sure does hide a multitude of sins!
FLguy8
FLguy8 can you please tell me if you used oil or latex based semi gloss. I have just purchased a 1973 31' Sovereign and am thinking of painting the walls as you did. What colour did you go with? Any ideas on filling old rivet holes prior to painting? Thanks
