Old 08-31-2010, 11:40 AM   #1
1965 26' Overlander
Wooden Interior Walls
Had to remove the remaining interior aluminum skin to get at 25 years of rotten insulation and general putridity. Some pieces were already removed/destroyed and the remainders were used to patch the belly pan and other invisible locales. I am planning to hang thin higher grade plywood on the interior walls.
I have seen a handful of threads with wooden walls but can't seem to find a good description of how best to hang the plywood. Remember, I don't have the interior aluminum to attach wood to. I'm assuming that I will need to fill the channels in the walls with pieces of wood for the screws to "bite" into and that I will need to score each individual piece.
Any thoughts on how best to undertake this process would be appreciated. It's gonna be "fun"!
Llano is offline   Reply With Quote
Old 08-31-2010, 11:51 AM   #2
_
REPLACE the inner aluminum skin.
then cover it with whatever U like (wood veneer for example)
the inner skin DOES provide some of the semimonocoque/unibody structural integrity...
that make streams streams...
inner skin connected2ribs connected2outer skin connected2floor channel (with flooring) connected2frame...
the curtains aren't structural elements
but just about every thing else is, in the old traylahs.
without exception the older threads on 'wood wall treatments' all have INNER aluminum skins intact.
those clowns on the diy channel,
did mutilate a stream with wood and carpet screwed to the walls.
THAT example is not to be followed.
cheers
2air'
Old 08-31-2010, 12:47 PM   #3
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
..did you say 'putridity' ? i like that word...!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 08-31-2010, 12:54 PM   #4
1965 26' Overlander
That's Texan for "rat poop and snake nests".
Old 08-31-2010, 01:23 PM   #5
pbearsailor's Avatar
Port Hadlock , Washington
I used 1/8"' Baltic Birch fastened with Olympic rivets and some bucked rivets (around the door). Used the existing ribs.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 09-18-2010, 08:43 PM   #6
any 1/8" ply should work but if you have the chance pick something up with cheap oak on the side that will face the trailer skin. The oak is very porous and should take to any glue you use to secure the sheets. Nailing, screwing or riveting into the interior skin should be enough to hold it providing you use enough, trying to block out the back or always hit the ribs is going to be a headache.
Chizlam is offline   Reply With Quote
Old 04-12-2016, 11:06 AM   #7
1989 25' Excella
Loretto , Tennessee
Wood Over Vinyl Interior Center Walls
I have gone through all the interior threads here and can't find anything about replacing the fake wood vinyl on the interior walls with something else. I am including a photo I found on Pinterest to show what our goal is. I found a 3/8 inch faux product at Home Depot that allows you to install shiplap planks. These are made of recycled wooden fibers, so they can be stained. But, how should they be attached to the walls? I'm assuming the wood grain vinyl is adhered to luan. Has anyone done this before? Did you remove the metal trim around the curves or just attach the boards over it? Did you use liquid nails, screws, or regular nails? I would so appreciate anyone's input here!!!
ID:	260553   Click image for larger version
EmilyK is offline   Reply With Quote
Old 04-12-2016, 03:03 PM   #8
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Adhesive(something like liquid nails) and brad nailer should work fine
Matt
rugjenkins is offline   Reply With Quote
Old 04-12-2016, 03:07 PM   #9
rugjenkins's Avatar
1975 Argosy 28
Leave the metal trim. The vinyl luan attaches to it.
Matt
sticky interior walls sovereign Upholstery, Blinds, Walls & Interior Finishes 64 08-14-2009 10:18 AM
Interior Walls tique79 Upholstery, Blinds, Walls & Interior Finishes 1 06-02-2007 03:16 PM
What Are My Interior Walls Dano57 Upholstery, Blinds, Walls & Interior Finishes 4 07-24-2006 06:01 AM
interior walls happier General Interior Topics 7 07-02-2005 01:04 AM
Interior walls dmadam Upholstery, Blinds, Walls & Interior Finishes 0 10-27-2004 05:59 PM
