Old 04-03-2008, 06:05 AM   #1
dreamin's Avatar
Salisbury , Maryland
Wood Trim, Bedroom, 2003 Classic
Hi all. Oops, it's a 2003. There is (was) a piece of wood trim just below the window. It appears to have been held on by thin 1" staples, but trying to straighten them and stick it back up doesn't seem to work. I'm afraid if I try to use screws I will tear something up. Any ideas? Thanks!
Terri and Chuck
2003 Classic 30' SO
2004 GMC 2500HD 4X4 D/A Ext. Cab
dreamin is offline   Reply With Quote
Old 04-03-2008, 06:15 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Depending on what's under where the strip is, you may be able to drill several small holes in the strip, and use small brass screws to reattach the strip.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 04-03-2008, 06:41 AM   #3
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Put a little silicone adhesive on it and tape it in place until the adhesive sets. Use just a little silicone, it works well
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
2003 Classic Pahaska 2001 - 2005 Classic 31 11-06-2012 09:42 PM
2003 Classic carpet Hal&Arlene Floor Finishes 4 01-28-2008 04:01 PM
2007 28' Front Bedroom Classic Craftsman 2006 - 2010 Classic (all lengths) 20 05-30-2006 11:37 PM
Protecting the wood trim during the stripping. Chaplain Kent Cleaning, Stripping & Polishing 2 01-03-2005 12:07 PM
Upholstery in 2003 Classic dreamin Upholstery, Blinds, Walls & Interior Finishes 5 10-25-2004 01:56 AM
