Old 01-05-2015, 07:12 PM   #1
Wood paneling ideas
I'm looking to completely gut a 70s airstream, and really want to do wood paneling on just the bubble ends. First, do I panel over the existing interior paneling? Also, I'm hoping there's people on here who are willing to tell me what they used for paneling, fasteners/glues, and techniques for cutting and bending panels.
Thanks!
Logan
Norskie is offline   Reply With Quote
Old 01-05-2015, 08:08 PM   #2
Also, I plan on putting reclaimed tongue-in-groove planks on the rest of the walls. Can I fasten those over the original factory paneling as well? And if so, how?
Old 01-05-2015, 08:21 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Wood over interior aluminum skins to keep shell integrity.
Threads on the subject:
http://www.airforums.com/forums/f36/...tml#post381115
http://www.airforums.com/forums/f321...tml#post186147
SeeMore is offline   Reply With Quote
Old 01-05-2015, 09:41 PM   #4
Does anyone have any experience/documentation with putting wood paneling OVER the factory paneling? So as to maintain structural integrity? How do you tackle running new wiring and installing new lights when putting the wood over the factory?
Old 01-06-2015, 01:42 PM   #5
1986 31' Sovereign
Miami , Florida
Are you planning on towing the trailer when you are done? Airstreams do have a finite gross weight and wood is relatively heavy. Might want to calculate the weight of the materials...
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-06-2015, 03:45 PM   #6
Yeah I plan on towing it. From my understanding, most people use 1/8th inch wood paneling split into 11 or 13 different curved pieces. I can't imagine that adding up to a substantial weight!
Old 01-06-2015, 08:35 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Woody..
Sounds like fun~
To rewire.. label all interior metal panels.. make aligning marks so you can reassemble... drill out the rivets... carefully store the metal sheets..
Buy some Klecos.. you'll need them.. oh, and the pliers too... Wear a mask to clean out the insulation and the likely mouse results.
Rewire... reinstall insulation.. reinstall the metal... then install the wood.
Oh, one tip might be to lay the metal sheet over the wood to mark where the rivets will be...
Buy the right tools.. and keep the blades sharp.
Have fun!
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-06-2015, 08:41 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Wood paneling ideas
I took the interior aluminum off, rewired to my taste, put the aluminum back and just secured 1/4" plywood to the walls using screws driven into the skins.
Easy cheesy!
Name:	ImageUploadedByAirstream Forums1420602021.319097.jpg
ID:	229936Click image for larger version
Name:	ImageUploadedByAirstream Forums1420602057.935514.jpg
My trailer weighs in at under 7,000 lbs.
I made a jig to make the cutouts for the electric boxes. The jig fit on the floor and gave me the right height for the cutouts on the walls, and it also showed me where to make the cuts laterally by lining up the jig with marks I had made on the floor when the walls were not up.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-06-2015, 09:39 PM   #9
Wow guys, thanks. I appreciate the info! J. Morgan - did you use 1/4" on the bubble ends too? One more dumb question, what do you mean by a jig?
Old 01-06-2015, 09:51 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My dear friend J.Morgan RAWKS!!! I am going to do this with my 1999 when it's due. I will probably (hopefully) get J. Morgan to come over and share some home-brew and laugh at my escapade!
Channing
WBCCI# 30676
Old 01-06-2015, 09:55 PM   #11
One more, what do you use the clekos for?
-- It's too bad you guys aren't in Montana, some air stream veterans would be nice on my first project!
Old 01-07-2015, 12:05 AM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Wood paneling ideas
I will post a picture of my jig tomorrow, this will make everything clear!
Essentially everything in the trailer is made of plywood, all of the walls are 1/4", i cut some 3/4" plywood into dimensional lumber to frame the cabinets, etc.
CWF, I will be proud to drink some home brew with you... And help out some too!
Old 01-07-2015, 02:05 AM   #13
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
A Bit of Insight
Clecos allow you to hold two pieces of sheet metal together in proper alignment for drilling or riveting. There is no better way to hold the panels in place (especially on curved surfaces) to ensure you can reuse the existing holes when reassembling the parts removed. This video clip will clarify:
https://www.youtube.com/embed/LfX10fcrRS4
FYI - Standard 1/8" paneling is much easier to flex than 1/4" for some of the curves you might be tackling. However, you may benefit from considering bendable plywood [also known as Curve-Ply, Flexply, Wacky Wood, and Wiggle wood] for tighter radius turns on the end caps. Bending plywood is normally made out of imported hardwood veneers (2 or 3 ply) with the grain layers all running in one direction which allows greater bendability to the panel. It is most readily available in birch and you can add a veneer to match almost any finish from exotics woods to laminates. When you see panels listed as 4' x 8' and 8' x 4', the difference is the direction in which the board will bend. When bent a 4' x 8' will stand 8' tall & wrap like a column. The 8' x 4' panel size will stand 4' tall and wrap like a barrel.
Old 01-07-2015, 09:44 AM   #14
Thanks again for the info guys! I look forward to seeing that pic, J. Morgan!
Wood Paneling: Recommend a good thread? Aktundra Upholstery, Blinds, Walls & Interior Finishes 13 11-26-2014 08:52 PM
Want to use wood paneling freerider Upholstery, Blinds, Walls & Interior Finishes 3 04-16-2012 08:48 AM
Old Walnut paneling different color than new walnut paneling geodazed Upholstery, Blinds, Walls & Interior Finishes 11 06-06-2011 07:53 PM
Wood Paneling niftypkg General Interior Topics 5 03-03-2007 07:24 PM
renewing interior wood paneling mjmcwhorte Cabinets, Counter Tops & Furnishings 16 01-05-2006 11:05 PM
