Old 11-30-2014, 07:54 PM   #1
1975 29' Ambassador
Fort Wayne , Indiana
Wood End Caps
I have been seeing pictures of wood end caps people are doing. They look beautiful.
What thickness of wood has to be used?
How are people attaching the wood.. cement glue.......screws.... rivits HELP!!!!!!!!
We have been experimenting with veneer to work with the curves... NOT working to well.
What is the easiest way to work with the curves.
Thanks SO much!!!!
tweetie1966 is offline   Reply With Quote
Old 11-30-2014, 08:29 PM   #2
Anchorage , Alaska
While we wait for a knowledgable reply to your questions, are you trying to do the end cap in 7 sections ?
Have you tried doing it in 13 sections ? I think it will reduce the complex curves
asked of any single piece. And it seems the paneled rigs are mostly the older 13 panel end caps. I think I've seen comments that these panels are almost flat (top-to-bottom).
I have seen a couple of installation threads using 1/8" Baltic Birch. The mill uses reject pieces to cover the pallet, and protect the paneling during shipping. My local specialty lumber store just gives these "cover pieces" away for free. I grabbed one to play around with, maybe make a pattern or two. But I have not yet messed around with it (still re-insulating, then electrical, then inner skins, then maybe paneling)
Aktundra is offline   Reply With Quote
Old 11-30-2014, 10:20 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Wood End Caps
Name:	ImageUploadedByAirstream Forums1417411120.722485.jpg
I just started installing pieces and ended up with this.
I used 1/4" plywood and it bent into place pretty easily.
No glue at all, all screws. We put one piece next to the other rough cut, marked the edge with a pencil, cut, and then did the final fitting wit a good dual action sander with 80 grit paper.
It SEEMED intimidating before I got started, but it wasn't hard, and I am in no way a skilled carpenter.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-30-2014, 11:08 PM   #4
Anchorage , Alaska
Looks like I can't continue to edit my initial post. But let me add, that I think I have seen references to installing the segments with an overlap like siding on a house or shingles on a roof, rather than the stringers-over-the-seams like J Morgan did. I have thought that this difference in heigh, between the edge on the skin and the edge on the lower plank (top to bottom), as well as using more narrow pieces, might mitigate the need for compound bends.
Please remember, all my comments are based on absolutely no personal experience.
Old 11-30-2014, 11:28 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I have seen the lapping boards also, they look pretty nice, a different style that will be more appealing to some based on what their tastes are.
Although the sections appear to have compound bends, (they appear to have compound bends in person as well as in photos) this is 99% an optical illusion, the sections are near entirely only bent on a single plain.
Old 12-01-2014, 02:48 PM   #6
Anchorage , Alaska
I like the contribution to the illusion that accents like the stringers provide, but also think the texture and "old school vibe" of lapping might be cool.
When I get my interior plan more fully developed in my mind, if I go with aluminum trim around the windows & doors, or counter tops, etc, I wanted to take a look at some aluminum extrusion 1/8 "J" channel that might capture the best of both approaches.
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
Replacing fake wood with real wood webspinner General Interior Topics 65 04-03-2013 09:13 PM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 07:38 PM
Wood end caps Canlib General Interior Topics 5 09-11-2010 11:45 AM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
