Old 02-01-2011, 01:11 PM   #1
Camp's Avatar
peachtree city , Georgia
Wood backing in replacement cushions?
Our 77 argosy 26 has two slide out couches with second/third edition cushions. Each seat-back has a plywood backing, the bottom cushions do not. Is this how the originals were made, or do I need to add plywood to the bottoms when reupholstering? There is a thin (1/4") wood panel on the slide-out frame and it doesn't look very supportive. I plan on reinforcing those panels. Thx.
'77 Argosy 26
2000 Excursion 6.8L
Camp is offline   Reply With Quote
Old 02-01-2011, 01:15 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Camp!
The luan plywood backers were added to the back cushions on the lounges to add necessary support for the cushions to prevent them from collapsing into the curvature of the wall. The backers can be added to the base cushions but it wouldn't be a necessity as it is with the back cushions.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 02-01-2011, 01:37 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Our GlobeTrotter sounds like it's similar - it has wood in the back cushions only. Both the seat & the backs have the same amount of plywood - it's just inside the upholstery for the back and outside on the seat. The seat doesn't need it inside because it lays flat on the plywood base attached to the glides both when they are opened and closed. The backs on the other-hand, use the plywood to support them in the vertical position when the glides are closed and it's made into a sofa AND to rest on when made into a bed and the glides are open. So it makes sense to have it move with the cushion. Make sense?
Shari
Old 02-01-2011, 03:36 PM   #4
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I just bought a panel of Luan plywood 1/4 inch and cut 2 sections that I used for the backing. My cushions were sewn together at the bottom but the Luan just rested against the backing. When I pulled the couch out I just slid the 2 sections down to lay flat. I was going to hinge them to the bottom but it worked fine without being connected
RichHog is offline   Reply With Quote
Old 02-02-2011, 03:39 AM   #5
Camp's Avatar
Thumbs up
OK, good info. I found an upholsterer with good foam and material for less than I could buy online. I'll pay him the labor to make some good looking loungers. Kevin, How do you like the winter so far? It's going to be cold, in the forties down here today. I know, that's cruel.
'77 Argosy 26
2000 Excursion 6.8L
Old 02-02-2011, 04:02 AM   #6
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Camp!
I live very near the Southernmost tip in the state of Illinois so our weather isn't all that bad. We have been as warm as 66 degrees three days ago. It was still 42 degrees at 11 p.m. last night. The back end of the Winter storm passed through in the wee hours of this morning and our temperature dropped just enough for a dusting of snow. We are supposed to have three to four days coming up that will be the coldest of the Winter for us - - daytime highs in the teens and twenties.
I lived in Western Kansas, Northern Illinois, and Southwest Wisconsin for nearly three decades so the weather back home in Southern Illinois seems quite mild now . . . .
Kevin
Kevin D. Allen
AIR #827
'77 Argosy entry door replacement Camp Argosy Motorhomes 7 02-02-2011 07:37 AM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 08:16 PM
A/C pan replacement Airhouse Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-28-2011 07:16 PM
Bending wood Splitrock General Interior Topics 0 01-21-2011 08:05 PM
Water Filter Sump Replacement elzavb Water Heaters, Filters & Pumps 1 01-11-2011 05:12 PM
