Old 09-07-2008, 09:49 PM   #1
1973 25' Caravanner
Santa Barbara , California
Window Shade Repair
I am hoping someone has some ideas on how to repair/replace the window shade in the front door of a 1976 Caravaner. The bottom edge is almost completely unstiched. I would appreciate insights from anyone.
Sheila Lewis
Sheilalew is offline   Reply With Quote
Old 09-07-2008, 10:14 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
What kind of blind is it... Do you have a pic...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-07-2008, 11:05 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sheila - Welcome to the forums.
I am at a loss for what a door shade in a 76 might be. A picture would be very helpful.
Richard
Old 09-08-2008, 06:00 AM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Sheila,
If it is anything like our 1987 you will have to drill out the rivets and remove the inside door skin in order to replace the blind.
Or you can do like we did...I pulled the blind out as much as I could and then used a razor knife to cut the blind off the roller. Then measured and purchased a spring loaded curtain rod and a cheap curtain. This method is a lot easier than removing the interior door skin.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-08-2008, 07:25 PM   #5
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Sheila,
Ours came unstiched as well a while back. I unrolled it as far as it would go and pulled the bottom out of the door opening. I re-stitched it by hand. Took about a half an hour. All fixed.
Tom
tlavergne is offline   Reply With Quote
Window shade slides bkahler Airstream Motorhome Forums 7 02-22-2007 08:07 AM
window repair Judy Barde Windows & Screens 7 11-26-2006 07:42 AM
Door Window Shade frozen chosen Windows & Screens 3 02-26-2006 11:09 AM
Window Repair 68LANDYACHT Windows & Screens 0 10-18-2004 08:30 AM
