Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 01-06-2009, 05:26 PM   #1
funkill
Profile:  1973 27' Overlander
Space Coast , FL
why did I think painting would be fun?
OMG - I am exhausted.... decided to paint Ophelia while on vacation. After reading several posts, I trekked to Sherwin Williams ready to purchase their Bonding Primer, Duration latex paint and then pick-up Krylon spray to do the front endcap. I left SW with a gallon of off-white Duration laytex interior paint and a quart of light blue-ish. And, a gallon of XIM primer. The store manager convinced me this primer would do for both the vinyl clad walls and the ABC plastic endcap.
I washed all the walls with (phosphate-free) TSP and double rinsed. Then I sanded the endcap with 120 and cleaned. This took longer than I expected and I was ready to get the primer on. OMG - the primer was pure hell. It *went off* very fast = gooey mess within about 10 minutes. It was a bit humid and I had all the windows open (as I was warned about the fumes) - but 10 minute working time??? And there was NO WAY to get it smooth on the end cap. I was even using the expensive moe-hair (sp?) smooth rollers. I decided to goop it on and sand afterward. Two days later and I'm still working on the end cap. I thought rolling on the primer would be less time consuming that taping all off for spraying Krylon. Now I wonder
Day two and I'm excited to start getting the Duration semi-gloss paint on the walls (re-address the end caps later). I got the cut-in portion completed. Two coats and worked on the end cap a bit more. Hopefully I'll finish on Day 3! This is really frustrating work. Not at all fun. Dang. But it does look nice and clean - smells fresh - and I am sure that, some day, I'll be really glad for the fresh look.
Laura
funkill is offline   Reply With Quote
Old 01-06-2009, 06:08 PM   #2
Kevin245
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Cool
Laura
I rate painting up there with wallpapering, root canals, and prostate exams. But I bet your work will bring many rewarding hours of enjoyment when it's all complete (not that working on the AS is ever complete).
Good luck...and keep on keeping us updated. Oh...and pictures.
Kevin
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Old 01-06-2009, 06:37 PM   #3
willyd
willyd's Avatar
Profile:  1993 34' Limited
Melbourne Florida , Springfield Ohio
Sure would be nice to see pictures. Thanks for sharing.
willyd is offline   Reply With Quote
Old 01-06-2009, 07:10 PM   #4
funkill
Space Coast , FL
Oh yes, I should take a few pics of the mess that I have on my hands now! You'll be horrified. And, hopefully, I'll be able to share pics of a much nicer completed project. Tomorrow I'll snap a few before tackling the sanding again. Sigh. What a job.
Old 01-07-2009, 06:25 PM   #5
danalee
danalee's Avatar
Profile:  1965 28' Ambassador
Walnut Cove , North Carolina
Images: 30
I have vinyl which someone has painted. I read that I should use the bonding primer but now I'm not sure - can you explain a little more about the problems you had? Thanks.
Dannie
The Silver Princess
danalee is online now   Reply With Quote
Old 01-07-2009, 06:44 PM   #6
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 220
Be careful with "Fusion" in a closed space.
Krylon Fusion produces an EXTREME amount of off-gas products - really nasty - but the paint really sticks to the plastic.
If you plan to use "Fusion" as a primer on the end caps you may want to top coat with "Rustoleum" or other color.
The can states you do not sand prior to painting, just clean it well with a "powerfull" cleanser - worked for me.
I have found that 3M "Blue" painters masking tape works better than most "off" brands.
Don't spray it too thick, and leave plenty of dry time between coats.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 01-07-2009, 07:51 PM   #7
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Painting is such sweet sorrow.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 01-07-2009, 08:22 PM   #8
vlamica
Profile:  2001 30' Limited
Novato , California
Send a message via Yahoo to vlamica
Painting.. i feel your pain.
2001 Airstream 30' S/O 70th Anniversary
1994 F-350 Crew 7.3 IDI Turbo, C6, Dually
vlamica is online now   Reply With Quote
Old 01-09-2009, 07:10 AM   #9
funkill
Space Coast , FL
I did not end up with the intended SW Bonding Primer, but another type - XIM primer. The XIM was suggested for use in lieu of Fusion (by the SW store manager) for priming my ABS plastic end cap. And he said that XIM was "even better" than their own brand of Bonding Primer - so that was all I needed to do the entire job (vinyl and plastic). I took him at his word and headed home with a gallon of XIM. I was warned to keep the trailer"well ventilated" as the fumes would be quite heavy. It was a nice day - 74F and windy - average humidity. I was also warned that it would "go off" fast so the manager said "get it on and get out". I opened all the windows in the trailer and positioned two small fans at each end. I poured the XIM in a paint tray and started cutting-in the edges. I did not find the fumes too bad (good air movement in the trailer) but noticed the XIM develop a skin on top quite quickly. Maybe 10 minutes max. Then, I would try to stir it in the paint tray and it turned into a gloppy mess. So, the idea of "getting it on fast and getting out" was really impossible. I had to pour only small amounts at a time and try to work in small areas at a time. I had the most trouble on the end caps. Getting in on smooth was very tough. Mostly because the primer gooped up so quickly and the odd angles of the end caps makes it tough to manipulate a roller (even a 6" one). I ended up putting it on pretty poorly - out of frustration - and sanding smooth later.
I'm not certain if I would use it again. It may have been my environment --- too much breeze --- too much humidity--????? But it was a total PITA.
Now that I finished, it seems that the smoothness of the primer at the end caps might not have been as critical as I thought before application of the top coat/laytex. I only hope that XIM is as good as the manager said and pray that I will never be faced with stripping the walls!!!
I will try to post some pics Monday. Today I'm leaving for a quick overnighter in Ophelia to celebrate my B-day! I'm hoping there won't be too many lingering paint fumes.
Old 01-09-2009, 12:06 PM   #10
Sixty3TW4US
Profile:  1963 24' Tradewind
San Diego , California
XIM Primer is an excellent primer however because it is a quick dry coating it performs best when sprayed, then you don't have to worry about lap marks, brush streaks etc. It has great adhesion on difficult substrates like glass, ceramic tiles etc. it is made for non-porous surfaces. Any type of finish paint latex or oil base can be applied over it. The SW bonding primer is a good primer for most applications. I'm sure after all is finished you will have a nice looking paint job!!
Sixty3TW4US is offline   Reply With Quote
Old 01-09-2009, 01:40 PM   #11
Jim & Susan
Jim & Susan's Avatar
McDonough , Georgia
Images: 37
Laura, I used the SW bonding primer and the Duration paint on mine. Now my walls are sticky, almost like the paint doesn't want to fully "cure". Did you have this problem? And how did you deal with it?
If you can't fix it with a hammer or a rivet, you have an electrical problem.
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 01-09-2009, 02:02 PM   #12
Sixty3TW4US
Jim; unforunatly latex paints can be sticky (not flat paints) in areas with high humidity. It can take up to 21 days for latex paint to cure. Never clean latex paint with products like 409, fantastic etc. they will make the paint soft and sticky. I like oil base products. Good Luck !!
Old 01-09-2009, 05:05 PM   #13
bilby05
bilby05's Avatar
Profile:  1969 31' Sovereign
Canyon , Texas
Ok, I'm convinced
My slightly discolored walls are beginning to look better and better after reading your tale of woe. I did use a coat of clear acrylic floor coating on the walls(as recommended by Inland Andy). I think I will do a bit of spray-paint work on the end caps and bathroom and bask in the glow of the more simple path. I tape and mask better than I paint. Although I do have that spot at the accordian(sp?) door area ceiling that has a crack. But maybe I'll just drill a small hole to stop the crack and use some creative decoration in that area. Anything beats extensive painting.
cheers, bill b.
bill b.
1969 Airstream Sovereign 31'
2001 F250 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 01-12-2009, 05:55 AM   #14
funkill
Space Coast , FL
Sorry for the late response --- out camping to celebrate my B-day. I did not, thankfully, have any problems like this. I found Sixty3TW4US's reply interesting. I had no idea that it could take 21 days for latex to cure!
Just for fun Isadora Off Topic Forum 6 03-10-2008 10:45 PM
Let's have fun. rebel beck Our Community 0 02-13-2006 11:03 AM
A Little Fun Edie Off Topic Forum 9 08-13-2004 01:30 AM
We need a little fun !! airstreamcaravel Off Topic Forum 8 10-11-2002 01:35 AM
Forums Directory
