Old 07-06-2008, 10:39 PM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
When did AS convert to plastic ceiling endcaps?
Hi--
I saw one of the new CCD Aluminum interiors at the Vernonia AS rally last weekend aand really like the look. I've read the sticky about the all the hard work required to strip them back to a nice shiny surface... but then remember that in the 60's or early 70's AS introduced new one-piece plastic end-caps.
I been searching the forum and can't seem to find a thread that answers this question. I'd like to konw when the interior ceiling end caps converted from painted or vinyl coated aluminum segement to the one piece plastic / fiberglass pieces.
Does anyone know the year or years AS did the change over?
Ron
ronstory is offline   Reply With Quote
Old 07-06-2008, 11:14 PM   #2
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Hi Ron:
Roughly, in the early 1960s. That change is not noted in sales literature, so has to be determined by inspecting late 1950s and early 1960s Airstreams. Owners of those era trailers can perhaps pinpoint it better for you.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 07-07-2008, 12:12 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I think it depends on the model...
Our '64 GlobeTrotter has plastic endcaps, but a friends '65 Caravel has metal endcaps. Our front has the molded in shelf unit...theirs has no shelf in front.
I think the larger models changed over first...
Shari
Old 07-07-2008, 05:27 AM   #4
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
My '68 Safari also has the plastic endcap with the molded shelf unit.
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 07-07-2008, 07:21 AM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
My '59 has both endcaps of aluminum but I've seen other '59 models with plastic. I believe the Ohio plant switched over before the California plant did.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-07-2008, 07:38 AM   #6
ronstory's Avatar
1975 23' Safari
Portland , Oregon
All--
Thanhs for the quick replies and it seems I'll have to get pictures or check it my self in in the pre 65ish models.
Thanks again,
Ron
Old 07-16-2008, 03:53 PM   #7
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Ron, Thanks for raising this question.
I'd like to know, also, if these interior end caps are structurally necessary, or are they cosmetic?
I'm thinking about replacing the rear fiberglass eventually with aluminum as part of relocating the rear bath and converting to a bedroom. The one-piece design is nice and clean, but I like the look of the panels outside repeated inside. I don't need the trailer to imitate a home, but to be something else, a retreat and playful space.
Anne
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 07-19-2008, 10:34 AM   #8
ronstory's Avatar
1975 23' Safari
Portland , Oregon
From what I've read form the experts on the forums, the end-caps add stiffness to the structure. I would consider the endcaps like plywood under the siding of house. The studs and joist carry the load... the plywood adds the rigidity.
You can definitely make and all alumnum replacements, and serval folks have threads on that effort. Your will need to use a fair number of panel (like the 50s style AS) to get the curve correct.
Ron
end-cap, fiberglass, plastic
Painting plastic front and bath ceiling in an Argosy Argy 78 Upholstery, Blinds, Walls & Interior Finishes 10 02-03-2008 03:03 PM
plastic ceiling panels art Upholstery, Blinds, Walls & Interior Finishes 10 01-12-2008 12:18 PM
plastic extrusion for Aluminum Panel Edge on Ceiling macbob1240 Interior Restoration Forum 3 08-29-2007 08:54 AM
Cracks in endcaps...and more Tin Lizzy General Interior Topics 1 08-14-2007 03:25 AM
'59 fiberglass endcaps 1959newbie 1954 - 1959 Overlander 14 12-14-2006 07:26 AM
