Old 10-30-2006, 10:23 AM   #1
2007 25' International CCD
Arlington , Virginia
What to clean Hull Liner with?
Have a "cream" colored "hull liner" which came with the trailer I purchased. It needs some cleaning. Any recommendations on what solution, products, etc..., to use to clean it with?
Streamer1 is offline   Reply With Quote
Old 10-30-2006, 10:27 AM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Not sure what this is. Is it a cover that fits over the outside of the entire camper?
www.nesa.org
Air No. 6427
Old 10-30-2006, 10:36 AM   #3
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Hull Liner is the fuzzy interior wall lining used on mid-90's trailers. One technique which worked OK but not great was to spray it heavily with diluted OxyClean while using a wet/dry shop vacuum to extract the moisture as it gravitated to the lowest points on the wall. The trick is to catch the moisture before it soaks the floor carpet.
So Long!
Bob Thompson is offline   Reply With Quote
Old 10-30-2006, 10:58 AM   #4
I will give it a try Bob. Thanks for the recommendation.
Old 10-30-2006, 11:56 PM   #5
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
When I was at the factory they sold me some degreaser that they use on all surfaces, says it works great on the drapes too. They might sell it at the Airstream store. I think I would try that dry spray spot cleaner that you do not saturate and then brush off with the lid. I have used that on upholstery and it doesn't leave a mark.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 10-31-2006, 12:51 AM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Patio furniture cleaner
The PO of our '66 Tradewind gave us a bottle of Patio Furniture Cleaner. She said it was the best product she had used to clean the inside walls. Now I don't know if the hull liner in yours is made of the same plastic material as ours but I offer the idea. I am not sure who makes the product. I can check tomorrow for you if it sounds like what you can use.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-10-2007, 08:02 PM   #7
galfoman's Avatar
2002 19' Bambi
Dorchester , Massachusetts
I too have some small stains on my "BLEEP"ING WHITE FUZZ LINER!.
WHO THE "BLEEP" PUTS WHITE FUZZ IN A CAMPER?
Ok I'm done.
I'd just be careful with what you use. If its too strong you will release the adhesive behind the fuzz.
What about Carpet Cleaner.
Carpets have glue and the cleaners are made for it. I think I will try that.
Just a thought.
G
galfoman is offline   Reply With Quote
hull liner on interior walls minuet7.3 Upholstery, Blinds, Walls & Interior Finishes 1 01-12-2006 11:41 AM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
