Old 03-13-2014, 09:01 AM   #1
1976 23' Safari
sherman , Illinois
Cool what paint to use on interior ?
i am getting ready to paint the interior walls of our airstream and wonder if anyone know about benjamin moore paint. i saw something on the forum about it and cannot find it again. help!!!
twodwoods is offline   Reply With Quote
Old 03-13-2014, 09:09 AM   #2
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I haven't tried this myself, but Krylon Fusion Plastic Paint is used and recommended highly by some skilled craftsmen here.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 03-13-2014, 10:50 AM   #3
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
Hello and welcome
And before you paint, what walls? The exterior walls, the divider walls, or the bathroom abs walls? prep and paint type might vary depending on what walls you mean. Hope we can help. And again welcome to the forums. PS we love pics! John
moparjohn is offline   Reply With Quote
Old 03-13-2014, 02:20 PM   #4
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
First I prepped the walls with a scrubby and degreaser. Then killz primer, then followed threw with 2-3 coats of satin paint. So far its proved to be durable for cleaning. Make sure you follow dry times before re-coating and outside temperatures if you travel down this route. Oh and open windows so you don't get dizzy.
Cyquest is offline   Reply With Quote
Old 03-13-2014, 03:14 PM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We painted the interior of our trailer 3 years ago. We made sure the walls are very very clean and rinsed very very well. Then we used Bondz primer and 2 coats of exterior latex paint. So far, so good. Some have used Fusion spray paint, especially on the end caps as they are plastic in some models. I think prep is more of a key than what paint you use.
Good luck, and welcome!
Kay
Old 03-14-2014, 08:33 AM   #6
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I just got finished painting our interior on the 65 Caravel. I lightly sanded the Zolatone finish, mostly to level the raised surfaces. I cleaned real good with Krud Kutter. Applied a Benjamin Moore tinted to match oil based primer they recommended. Final top coat was Benjamin Moore Super Spec HP Alkyd oil base paint. It turned out great. Time will tell, but the surface seems to be very strong. It certainly brightened up the interior.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 03-14-2014, 09:13 AM   #7
Wayward's Avatar
Cary , North Carolina
I'm a long time user of KILZ and BIN priers, I am now also using a primer called STIX by Insl-X (an Benjamin Moore company).
I know where it got is name. It sticks to darn near everything (including PVC, vinyl, plastic, glass, tile, glossy paint, fiberglass, and galvanized metal). Pretty much any paint will stick to it.
Cleans up with water.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 03-14-2014, 09:27 AM   #8
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I found the reference to Krylon Fusion:
http://www.airforums.com/forums/f179...-114620-3.html
Skatiero does fabulous work restoring trailers.
Poppy
John & Vicki
WBCCI #4291
Want to remove original interior paint finish on 64' what is best way? Olivebranch Upholstery, Blinds, Walls & Interior Finishes 6 02-08-2012 11:52 PM
Interior Panel order kitter General Interior Topics 5 01-29-2012 05:22 PM
Interior Rivet Colors perryg114 General Interior Topics 2 12-06-2011 08:14 AM
How to deal with this paint issue? Eaglemate Clearcoat, Exterior Paint & Trim 4 09-13-2011 10:46 AM
Interior paint? Phrunes Upholstery, Blinds, Walls & Interior Finishes 5 07-02-2011 12:20 PM
