Old 06-28-2011, 08:57 PM   #1
Murphree's_Law
bamurphree's Avatar
1967 22' Safari
1966 26' Overlander
Mt. Holly , North Carolina
What kind of wood was used in 1967 Safari
Can anyone tell me what kind of wood may have been used in my 1967 Safari? I am currently refinishing all the cabinets and panels and I need to replace one of the closet doors. I can't tell if it is oak, maple, walnut....anyone know? Thanks, Brett
bamurphree is offline   Reply With Quote
Old 06-28-2011, 09:00 PM   #2
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Mine was oak plywood. Was being the keyword here. I ripped it out and put in knotty alder.
ddstech is offline   Reply With Quote
Old 06-28-2011, 09:05 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Oak for the frame work and Oak plywood for the doors. Not sure if a different wood was used on an International.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 06-28-2011, 09:23 PM   #4
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
the international had mahogany, typically a darker color with wood not as tightly grained.
kevin
kevinb is offline   Reply With Quote
Old 06-28-2011, 10:08 PM   #5
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Hi,
I have a '68 Globetrotter and replaced slot of upper cabinets with birch plywood. The doors in mine looked to be an oak plywood. I lighted the cabinet finish to match the original.good luck.
Randy Gates is offline   Reply With Quote
Old 06-28-2011, 11:03 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Welcome to the forums. Airstream trailers could be customized with different interior and exterior trim levels and materials/fabrics. Mine is an International trim package and has Mahogany plywood (dark) and Aqua fiberglas and formica throughout. If the level was basic trim package Oak or Birch plywood (Light) with Yellow fiberglas and formica was widely used in both Califoria and Ohio built units. Of course that was standard factory stuff. Your trailers' original owner could have had anything custom installed at time of order or as an after market upgrade. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-29-2011, 01:55 PM   #7
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
ANN ARBOR , THE GREAT LAKES
According to my research, the 68GT was available standard with ASH, and optional with Mahogany. Your 67 could be Ash if it looks a bit like oak. I believe for sure that my 68 is Ash, as I do a fair amount of finish carpentry, and have removed and resawn most all of it for my new floorplan with side dinette.
I don't believe that Ash plywood is easily available. The grain is similar to some variances of Oak, so that is what I am using when needed. You really can't tell the difference unless you're a wood grain fancier. Ash can be mistaken for Oak. The natural color of Ash fits between red and white oak. In 68, Airstream sprayed the interior with clear lacquer, not varnish.
Ash is a very fine wood. Because of its flexibility It is finely split to make baskets. Consider yourself very lucky if you have an Ash interior.
ALUMINUMINUM is offline   Reply With Quote
Old 06-29-2011, 03:41 PM   #8
1972 25' Tradewind
McHenry County , Illinois
Had Ash in my '67 Globetrotter. It does look a lot like Oak. The sales book from that year also says Ash or Mahogany.
The species was confirmed when I took a door to the local Hardwood Supplier.
Veneer plywood of every imaginable variety is readily available, but you will need to go to a lumber supplier that caters to the woodworking and furniture building hobbyist.
Good luck,
Tom
Tom Nugler is offline   Reply With Quote
Old 06-29-2011, 05:06 PM   #9
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
I believe the lacquer finish was used only on ash/oak while a natural oil finish was applied on mahogany cabinets.
Kevin
Old 06-30-2011, 02:43 PM   #10
Murphree's_Law
bamurphree's Avatar
1967 22' Safari
1966 26' Overlander
Looks like it must be oak. Thanks for the replies. Happy camping
Old 01-11-2012, 09:31 AM   #11
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Just getting to the interior wood on my 67 Tradewind California built and mine had a pickled type finish. I'm no expert but asked somebody that does a lot of woodwork and they thought the wood in mine was ash. Going to bring some of the old woodwork to a hardwood supplier this AM to see what they think as I am ready to purchase some sheets of 1/4" to do the walls between bath and sleeping area. Will report back with what I find out.
SilverHoot is offline   Reply With Quote
Old 01-11-2012, 09:51 AM   #12
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Brett
My 66 Tradewind looks like oak to me, but I have been told that it is actually ash.
Dan
Old 01-11-2012, 03:14 PM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
my 66 has ASH too
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-11-2012, 04:06 PM   #14
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
My '67 Trade Wind has ash, too. It was originally that weird pickled finish. If you sand that off and give it a clear finish, it is absolutely beautiful.
Vaughan
Old 01-17-2012, 11:53 AM   #15
1968 22' Safari
Chico , California
Luan Mahogany
Hi there,
I asked my father, the original owner of our 1968. The wood is Luan Mahogany. Google it, this is absolutely correct.
Bessie1968 is offline   Reply With Quote
Old 10-17-2013, 02:10 PM   #16
asbury park , New Jersey
I wanted to update this thread for posterity's sake; I've researched this extensively in anticipation of replacing a panel in the 67 international.
From what i have researched it seems that the 'mahogany' used in the 67 international is 'Philippine Mahogany", which is not really a true mahogany. The Wood that can be called "Philippine Mahogany" or Lauan / Luan, is also known as Meranti, all come from southeast Asia, and used to be made of wood from the Lauan tree.
Today what we think of as 'Luan' (cheap, thin tropical hardwood plywood) is really a different species than what is was in '67, no longer coming from Philippines. Most true Phillipine Lauan is totally gone and now unavailable due to deforestation. What we are really getting when we ask for Luan is a muti-species product that is not really from true "Lauan" trees, but instead from multiple species from Malaysia and other SE Asia countries.
So, I picked up some of the red 'luan' and will try to match the finish with stain (restore-a-finish , mahogany flavor). Seems to be the best / only option. Hope someone finds this useful in the future.
NJtoNC is offline   Reply With Quote
1967, 1967 safari, cabinet, refinish
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
1967 Airstream Safari 21' (Refurbished) eBay Watch Airstreams on eBay 0 06-10-2011 04:10 PM
Vintage 1967 Airstream 22' Safari, Project or Parts eBay Watch Airstreams on eBay 0 05-17-2011 06:20 PM
1975 Excella 500 what kind of wood veener I have? Mypanhead Cabinets, Counter Tops & Furnishings 3 04-27-2011 08:38 PM
Feast of Spring Rally at Penn Wood Airstream Park PA Camper WBCCI Rallies & Events 0 04-06-2011 06:14 PM
