Old 06-12-2012, 06:43 PM   #1
1989 29' Excella
Tyrone , Georgia
What is the velour wall covering called in my excella and should we put it back up?
Hey all! We are finishing up our renovation and have a question about the blue velour panels that were originally installed in the front and back sections.
We noticed that the new airstreams just have aluminum next to the bedding. What are your thoughts on this? Is it something we should fabricate to get fabric back in place or just leave it aluminum?
Thanks!!
mikeandnora is offline   Reply With Quote
Old 06-12-2012, 06:52 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
My 75 has the velour panels. We plan on putting them back in, the walls get C-O-L-D in the winter time.
Aaron
WBCCI #XXXX AIR #2495
Old 06-12-2012, 07:46 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Look up "Hull Liner."
Old 06-12-2012, 08:04 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We made some 18 inch high insulation panels out of foam core poster board covered with a little more foam and then glued on 1/4 in. thick fabric that is used for liners in music instrument cases. It give better insulation when you roll up against it during the night. The funeral curtains cover most of the wall area in our 34 footer with twins. The vinyl covering in the other areas do not seem to radiate the cold that much.
