Old 07-25-2007, 08:04 AM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
What is the best way to fix this?
Above the valance for the front wrap windows the ceiling is covered with vinyl rather than aluminum. When we were cleaning, we discovered this lovely crack which was "hidden" by the previous owner with various trinkets that were velcroed to the shelf in front of it. It appears that there is some stress on the crack as it does not naturally line up. This makes repairs very difficult. Anybody got any ideas about the best way to fix or hide this?
ID:	41925   Click image for larger version
ID:	41927   Click image for larger version
chuman70 is offline   Reply With Quote
Old 07-25-2007, 09:26 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I would first sew it up to take pressure off of the split so that it doesn't go any further. I would then take a piece of vinyl material as wide as the entire shelf area and tall enough to cover the split and glue it to the area. I would consider doing it in a contrasting color to use as a backdrop for items that you may want to display on the shelf.
SuEllyn & Brian McCabe
Old 07-25-2007, 10:14 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I had a similar problem with my Sovereign, but my end cap is plastic. I used Epoxy Putty to fix the crack. After I finished the repair, I painted the entire end cap to hide the repair.
Being that your end cap is vinyl, I would fashion another piece for the front to cover the rip.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-26-2007, 01:29 PM   #4
1974 25' Tradewind
It may be plastic. I'm not sure.
Old 07-26-2007, 01:31 PM   #5
1974 25' Tradewind
That is kind of what I had in mind. Do you know of anyone who could make that for me? I'm not that talented.
Old 07-26-2007, 01:46 PM   #6
That headliner is plastic.
They can be repaired or replaced.
If you repair it carefully, then paint it, the problem will be over.
Old 07-26-2007, 01:55 PM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Andy is right. You can use either epoxy putty or a fiberglass repair kit to fix the crack then when its dry, paint it.
1958 Overlander
4CU 1st VP
Old 07-26-2007, 02:46 PM   #8
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Hey Chu- Everyone has great input here so here is mine. I would get a piece of mesh behind the tear in the plastic, drill a series of #20 holes on each side of the damaged area, rivit one side then position the two pieces as best as possible and rivit the other side. Now you have a strong bond and foundation on which you can now start to epoxy. I would lay down one thin coat, let it dry, sand and then apply another coat and continue the process till you have a smooth even surface. Now you can go in and paint.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 07-08-2008, 11:59 AM   #9
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
My 76 Sovereign end cap had cracks in it. I used fiberglass tape and caulk to stabilize them and then covered the entire end cap with vinyl wall covering. I used sizing, self glueing wall covering and extra construction adhesive to make sure the vinyl would stay up at that angle. Working overhead meant most of the glue was put on by hand and smoothed out with the vinyl wall covering application. Rolled the seams and it's held very well for almost a year. It certainly brightened up the trailer by covering the yellowed end cap plastic and was an inexpensive fix. By the way, all the glue I used was water soluble to make it easy to work with and allow it to bond to the wet vinyl wall covering.
ID:	63346   Click image for larger version
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Wish AND FIX UP list for MH PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 35 07-25-2009 09:49 AM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
