Old 03-18-2010, 09:55 AM   #1
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
What I think I know about painting vinyl interiors
1. It is possible to paint the vinyl wall coverings in vintage Airstreams.
2. These walls coverings can become sticky over time. The "plasticizer" used in the vinyl separates ("spews") and creates a tacky texture. This can be removed using a range of cleaners, but cleaning the surface does not remove the plasticizer from the vinyl. Over time, the same stickiness can reappear.
3. As with all painting, preparation is key. It is important to completely clean the interior and scuff it with a sandpaper of around 150 grit. Abrading the surface creates better adhesion between paint/primer and the vinyl wall covering.
4. In general, oil-based primers and paints seem to have enjoyed more success than water-based latex coatings.
5. Good results have been reported using Zolatone, but the product requires some degree of expertise and it is more expensive than other interior coatings.
6. The platicizer can bleed through new primer and paint. The amount of "stickiness" seems to depend on a number of factors including the primer and paint used. Some success has been achieved by using MinWax PolyCrylic as a top coat.
7. Oil-based paints and primers are reportedly better at "holding back" the plasticizer from bleeing through. Widely available primers like Kilz and Zinsser have been mentioned as have Sherwin Williams and Benjamin Moore. I couldn't find any data on products like marine epoxy primer (which does intrigue me).
hampstead38 is offline   Reply With Quote
Old 03-18-2010, 10:11 AM   #2
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Our '67 arrived in our care with the walls already painted (a wonderful combination of dark green, pale pink, and baby blue, not to mention the floral wallpaper borders). On our first reno, we just prepped the paint that was already there, gave everything a good coating of Kilz, and covered all with a clean off-white. Second reno, I decided to experiment with removing the paint and exposing the original vinyl. Many hours of citrus stripper and scraping later, I was once again prepping the walls (IIRC, around 220 grit), applying a coat of Kilz, and re-applying the off-white. We've had our Safari now for almost 6 years, with no issues with peeling or bleed-through. All of our products were latex. Your mileage may vary.
Mel
Mel is offline   Reply With Quote
Old 03-19-2010, 07:39 AM   #3
funkill's Avatar
reno , NV
Images: 27
That seems to sum it up!
I wasn't satisfied with my wallcovering even after cleaning it. I went the route of paining (XIM primer and S/W Duration Latex). Walls then got sticky, suposedly due to primer. Coated with PolyCrylic per S/W representative and it seems to have rectified the condition.
Laura
funkill is offline   Reply With Quote
Old 03-19-2010, 09:42 AM   #4
1967 26' Overlander
Upperco , Maryland
Having read all of the thread on painting vinyl wallcovering I could find, I just tried to put everything in one place. XIM makes a primer specifically for plastics. My impression from other threads is that XIM primer works well, but it does not stop the migration of plasticizers through to the surface. I've continued to do some research on sealers though I have not found a product that would both prime the vinyl surface and stop the plasticizer from bleeding through to the surface. While I'm not a chemist, it seems that the oil/alkyd based paints have less porosity than than latex. Your post confirms the success of using a PolyCrylic topcoat, however, this means adding another evolution of painting the interior (primer, paint, sealer). It would be nice to find a primer or paint system that would eliminate the need for a sealing topcoat.
Old 03-19-2010, 01:13 PM   #5
IggyWalker's Avatar
2014 30' FB FC Bunk
1986 25' Sovereign
1968 30' Sovereign
Vestavia , Alabama
We are planning to paint the interior of our '87. The Benjamin Moore dealer here recommended a bonding primer called "Stix", and then a topcoat of whatever we like. I actually went to the store twice and two of the sales associates recommended the Stix and one recommended the XIM. The possibility of yellowing with UV light and gas heat with the oil based products was mentioned by one of them. I think we will use the Stix, although my neighbor had great success in painting her kitchen laminate counter tops after priming with XIM....
IggyWalker is offline   Reply With Quote
Old 03-19-2010, 01:42 PM   #6
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
Personally,I would use oil based Primer called Cover-stain made by Zinsser ,and have the primer tinted to the color that you choose,and use a high quality latex eggshell or a flat (preferably a ceramic topcoat, The Sales person was correct,in saying that lighter oil based colors will yellow with exposure to sunlight and gas heat.. look at white oil based trim in a home 3 years after it has been painted,Any questions feel free to P.M me,as I also am a professional painter,Thank You
Rollerboy is offline   Reply With Quote
Old 03-20-2010, 02:13 PM   #7
1967 26' Overlander
Upperco , Maryland
If do latex, we'll go with a speciality primer like XIM and immediately apply a couple of coats of the PolyCrylic... anticipating the "sticky wall" issue. I'm not worried about the paint yellowing... and we're probably not going to use white/off white inside the coach. Gotta have the strong colors.
Old 03-22-2010, 08:08 PM   #8
IggyWalker's Avatar
2014 30' FB FC Bunk
1986 25' Sovereign
1968 30' Sovereign
Vestavia , Alabama
FWIW, After some research, I have found that the Insul-X Co. who makes Stix bonding primer is owned by Benjamin Moore. According to the Insl-X website: "In March of 2008, Insl-x Products Corporation became a wholly owned subsidiary of Benjamin Moore & Co." Not that there is anything wrong with that
I have not been able to find much actual field use information about this Stix primer online in the AS or various paint forums, or from personal contacts that indicate it's quality, good or bad. We have renovated many houses without a problem using original Kilz, etc. but this project is so completley different and we want to do it right.
I think we may try the XIM primer after all...The interior is maybe halfway prepped/sanded afer a week of work. Have to decide soon! Yellowing does not concern me that much either, even though we may use off white since we have other srong color fabrics. We have lots of 80's oak cabinets to offset, LOL!
Old 03-23-2010, 07:15 AM   #9
1967 26' Overlander
Upperco , Maryland
My impression is that the XIM will work well in creating a positive bond between the vinyl wall covering and the paint. What it does not seem to do is stop the migration of plasticizer. The paint colors are important to my wife and she's found some colors in the Olympic latex brand she really likes. I figure the thing to do is just shoot a couple of coats of PolyCylic while I have everything taped up. We would get the colors we want and the best possible chance of avoiding "sticky wall" syndrome.
Old 03-26-2010, 01:15 PM   #10
1967 26' Overlander
Upperco , Maryland
Ordered XIM
I ordered a gallon of XIM Plastics Bonding Primer. It is about $68 from the local Sherwin Williams, special order. I plan to finish cleaning the interior and scuffing everything this weekend. With luck, I'll be rolling/shooting the primer next week (weather allowing). I'll post a report on how it goes.
Old 03-26-2010, 03:14 PM   #11
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
XIM is GREAT Stuff,Curious to see how the stickiness goes for You .
Old 03-26-2010, 06:08 PM   #12
77 R GO C MH's Avatar
1977 28' Argosy 28
Lincoln , Nebraska
This is a common problem for all of us. Keep it simple.
I have used odorless paint thinner to wipe it all down 3 yrs. ago.
Painted the surfaces with latex paint. Still just like new and
no sticky residue.
77 R GO C MH is offline   Reply With Quote
Old 03-26-2010, 06:20 PM   #13
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
All plastics and vinyls are kind of like a 'damper' for just about any kind of paint. In my many moments of airbrushing just about everything under the sun moon and stars--plastics and paint just don't want to mix. Dry times seem to take forever...and ever...and then some. I have concluded that I don't like it at all...you would think the interior shell would have enough 'tooth' to it to hold paint, and it certainly does. But we are keeping our walls 'as is'. Humidity doesn't help either. But I will add this product, and you will laugh and throw tomatoes at me but this dollar store spray on product is the best darned cleaner I have ever worked with- even if it says its made for something else. It will strip the surface and bleach it with out harming it and you will see the grime virtually melt when it hits the surface. After wiping away with a sponge and warm rinse water, it leaves the wall bright dry and brand new again, and its only about three bucks a bottle.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-26-2010, 06:47 PM   #14
3blessed's Avatar
2012 19' International
1986 25' Sovereign
St. Tammany , Louisiana
Hey guys, I just happened to be perusing through Inland RV's website today and saw Andy's idea about using Future floor wax to shine up that vinyl. Looks better than paint to me. What do you think?
3blessed is offline   Reply With Quote
paint
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 01:35 AM
Vinyl stripe painting pacer General Repair Forum 5 06-18-2009 01:22 PM
Painting interior vinyl? 415Hoop Upholstery, Blinds, Walls & Interior Finishes 2 05-16-2007 12:46 AM
Painting over vinyl/plastic veneer on cabinets suzylugz Cabinets, Counter Tops & Furnishings 14 08-27-2006 06:20 PM
Painting the vinyl coated... geof Upholstery, Blinds, Walls & Interior Finishes 1 04-28-2003 10:37 PM
