Old 08-03-2011, 05:17 AM   #43
my3sonsdad's Avatar
1975 Argosy 26
Vienna , VIRGINIA
Great to hear!
1975 Argosy 26
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 08-03-2011, 02:59 PM   #44
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Originally Posted by adwriter73 View Post
i have a "1 year report"...
paint still holding up. even in our 32 days straight of 100+ temps in texas!
P.S., I did the same technique as Hampstead38 minus the final polycrylic. I was concerned about that finish yellowing over time. My interior is bright white.
adwriter73 is offline   Reply With Quote
Old 05-26-2015, 10:02 PM   #45
Auckland , California
Originally Posted by Mel View Post
Our '67 arrived in our care with the walls already painted (a wonderful combination of dark green, pale pink, and baby blue, not to mention the floral wallpaper borders). On our first reno, we just prepped the paint that was already there, gave everything a good coating of Kilz, and covered all with a clean off-white. Second reno, I decided to experiment with removing the paint and exposing the original vinyl. Many hours of citrus stripper and scraping later, I was once again prepping the walls (IIRC, around 220 grit), applying a coat of Kilz, and re-applying the off-white. We've had our Safari now for almost 6 years, with no issues with peeling or bleed-through. All of our products were latex. Your mileage may vary.
Hi, I read your post with interest. We have a 64 Globetrotter that has been painted in a 'rag roll' type of style over the original vinyl. Am I correct in assuming you gave up on stripping the paint back to the vinyl and just painted over the paint again? Thanks, Angela in NZ
Sparks nz is offline   Reply With Quote
Old 02-19-2016, 05:00 PM   #46
Satellite Beach , Florida
Originally Posted by lgastall View Post
I recently painted my interior with a primer called Bin. I thought it worked brilliantly! You can paint the Bin primer on to the cleaned vinyl even if it is sticky; so far it seems to have prevented the stickiness from bleeding through. It also blocks stains and does not require prior sanding.
I have explained it more thoroughly on my blog.
Lucy.
Hi Lucy,
We just purchased the BIN per your recommendations to paint our interior. Did you paint overtop of the all of the "metal" trim throughout, or did you cut in around that? I have yet to see a remodel that appears as though the metal trim was NOT painted over, but I just wanted to be sure before we paint. I'm a bit concerned about adhesion to the "metal" and the durability as most of this trim is on edges, corners, etc that will get much more wear and tear.
Thanks in advance!
Sue
suzuz22 is offline   Reply With Quote
Old 05-20-2016, 01:19 AM   #47
Fostoria , Ohio
Primer and paint questions
I have problems with fumes and so forth and wanting to try using Kilz Premium primer, which is latex. Has anyone used that and if so what were your results? I really don't want to use anything oil based if I don't have to. I would then like to use a good latex on top suggestions? thanks
appygirl is offline   Reply With Quote
paint
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 01:35 AM
Vinyl stripe painting pacer General Repair Forum 5 06-18-2009 01:22 PM
Painting interior vinyl? 415Hoop Upholstery, Blinds, Walls & Interior Finishes 2 05-16-2007 12:46 AM
Painting over vinyl/plastic veneer on cabinets suzylugz Cabinets, Counter Tops & Furnishings 14 08-27-2006 06:20 PM
Painting the vinyl coated... geof Upholstery, Blinds, Walls & Interior Finishes 1 04-28-2003 10:37 PM
