Old 05-28-2012, 04:30 PM   #1
1989 29' Excella
Tyrone , Georgia
What do you think about this? Magnetic privacy.
Ok guys. We are renovating the excella and I think we may have come up with an idea to kill the drapes but keep the privacy.
What do you guys think about replacing the roller vinyl with blackout fabric and sewing in miniature super magnets? Then, use a glue gun to place super magnets up and down the inside of the window frame.
Pull the shade down and it should stick to the frame. We will trim the roller so that its width is within the width of the window adjustment handles.
Skatiero, sorry no picks yet!! I'll try for this week!
mikeandnora is offline   Reply With Quote
Old 05-28-2012, 04:33 PM   #2
bbqmama's Avatar
1967 20' Globetrotter
Broomfield , Colorado
Now that is a slick idea!
bbqmama is offline   Reply With Quote
Old 05-28-2012, 05:12 PM   #3
1974 Argosy 20
Kooskia , Idaho
You may find a problem with the magnets being too strong, or too week. Like Goldylocks you will need them "just right" so you are not fighting them. My experience with the supermagnets is that often they just won't let go. But you will never know until you try it. Do some experimenting first with one or two, before you go for the whole shade.
Old 05-28-2012, 05:50 PM   #4
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Great idea, just watch hose magnets arOund things like cell lines if you all charge yours over by the window using that outlet by the stove like we do!
Yes, yes, post pictures!
Skatiero is offline   Reply With Quote
Old 05-28-2012, 06:07 PM   #5
1989 29' Excella
Tyrone , Georgia
Thanks for the input everyone! I can imagine the issue of strength being critical. Especially since the magnetism must go through the aluminum and the width of the fabric. I will see what I can get locally to try and test out the options first.
Old 05-28-2012, 07:43 PM   #6
1988 32' Excella
Robbinsville , New Jersey
If the magnets are too strong you could use metal washers on one side.
Old 05-28-2012, 07:46 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I never thought about the frames being ferrous....
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 05-29-2012, 07:15 AM   #8
1989 29' Excella
Tyrone , Georgia
It's not. They are definitely aluminum, so we'll have to place something behind them.
Wazbro, that is a fantastic point. Looking at magnets online it appears that I can get tremendous pull strength out of a magnet that would fit behind the frame, so why not just go for the maximum amount of pull that is hidden and "adjust" the force by trying different locally available washers or other ace hardware stuff.
Old 05-29-2012, 07:39 AM   #9
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Great idea using magnets but I wouldn't think you would need that strong of a magnet to hold the material in place.I know our local HD and Lowes carry different sized magnets and one of the two carry the neodymium magnets.
Have you checked these magnets out?
Neodymium Magnets 0.375 inch x 0.125 inch Thick Rare Earth Disc Magnet with 0.25 inch x 0.125 inch 90 degree countersunk hole
http://www.magnet4less.com/product_i...roducts_id=980
desertair27 is offline   Reply With Quote
Old 05-29-2012, 08:23 AM   #10
1989 29' Excella
Tyrone , Georgia
That is the site I was looking at. If the local stores carry anything that will fit I will try them in case of return.
Even if the ones at home depot are not the perfect fit behind the frame at least I will get an idea of the pull strength needed prior to ordering a bunch.
Old 05-29-2012, 08:23 AM   #11
1988 32' Excella
Another thing to think about I have seen magnetic tape at Home Depot.
Old 05-29-2012, 08:29 AM   #12
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I am a teacher and use magnetic tape a lot-- it is great.
Old 05-29-2012, 08:39 AM   #13
1989 29' Excella
Tyrone , Georgia
I was thinking it would need a pretty powerful little magnet to go through the aluminum. I'll try tape as well though.
Old 05-29-2012, 09:01 AM   #14
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
You could also use thin steel strips on the inside of the skin. You could paint it to match the skin so it blends in. Use 3m tape to secure it flush with the skin. This would give you a surface that the magnet could stick to at whatever height you like.
Eric H is offline   Reply With Quote
