Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 07-19-2007, 09:20 AM   #1
Tin Lizzy's Avatar
Profile:  1989 34' Limited
Fort McMurray , Alberta
waterproof wallpaper
Does anyone have one of those sit-down showers whereby the walls are covered with a seemingly 'waterproof' wallpaper. It is old, and outdated. I want to replace it. Has anyone replaced this paper or do they go directly to one of those fibreglass sheets and cut to fit instead??? Any ideas would be helpful. Also, when I redo the wallpaper I want refinish the the actual basin by giving it a new finish/color. Right now it is that aged/dull yellow/beige. I dont want bright white, but an off white. Anyone recommmend any specific product/process for spraying it? Can I spray it in place?
Thanks!!!!
A balmy +34C here!!!!!! Ugh....
James, Dee and Ms.Tina
Air #12102
Tin Lizzy is offline   Reply With Quote
Old 07-19-2007, 10:34 AM   #2
NEU President 2009-2010
myboyburt's Avatar
Profile:  1993 25' Excella
1977 Argosy Minuet 6.0 Metre
New Boston , New Hampshire
Images: 12
Thanks!!!!
We had the same issue and solved it by sanding the wallpaper and painting it with a paint designed to cover old laminate counter tops. We did this three years ago and it is holding up perfectly. I believe the paint is a Ben Moore product.
We have the same problem with the tub. We will be painting it with POR-15 Whitecoat this year. They sell another product called Hardnose (or something close to this name) that comes in a few colors that would work too.
Michelle & Leon
WBCCI # 7032
New England Unit
White Mountains NH Unit
Vintage Airstream Club
Tin Can Tourists Vintage Club
Our 2009 Airstream Adventure!
myboyburt is offline   Reply With Quote
Old 07-19-2007, 11:54 AM   #3
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
wallpaper...
You can replace the existing wallpaper with vinyl wallpaper or paper over it, just be sure that your existing substrate is solid so it will adhere and not fall down.
Dwight
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Stripping interior vinyl covered walls Anna Upholstery, Blinds, Walls & Interior Finishes 57 09-21-2009 10:32 AM
Wallpaper failure in shower, what to do? ldetsf Upholstery, Blinds, Walls & Interior Finishes 5 11-02-2006 04:02 PM
Awnings - Waterproof??? Tin Lizzy Awnings 7 05-15-2006 11:39 AM
Wallpaper falling off overlander76 Upholstery, Blinds, Walls & Interior Finishes 3 07-04-2003 08:55 AM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 05:52 AM
