Old 10-15-2010, 01:37 PM   #1
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
Washing curtains, worried about tabs
Has anyone washed their curtains? I don't suppose it's something anyone does often but since I have pets I'd really like to wash mine every few months. I'm worried about putting them in the wash because of the tabs, I don't want them to break in the machine and damage it. I have a mesh laundry bag but I think the holes in the mesh are large enough that the tabs will poke through during the tumbling process.
MonaxLisa is offline   Reply With Quote
Old 10-15-2010, 03:16 PM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
We handwash in lukewarm water with a mild detergent, then hang to dry. We figure gentle washing will extend the life. We have seen older curtains disintegrate in the washing machine as the UV rays break down the fibers.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 10-15-2010, 04:25 PM   #3
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
I have washed ours in the tub and hang on the adjustable spring tension shower curtain rod (relocated to the center of the tub) to drip dry on hangers with clips to hold them vertically as they would hang on the windows. They come out very nicely.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 10-15-2010, 04:59 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Hand washing is definitely the way to go...machine washing would be too rough and the elastic on the clips will lose its elasticity if washed too often and too furiously.
TB & Greg and Abbey Schnauzer
#3954
TBRich is online now   Reply With Quote
Old 10-15-2010, 06:19 PM   #5
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Dry cleaning works too. One set in our kitchen area was water and tomoato stained by PO. They look new now.
BTW - are the tab attachmnets elastic or not? Ours do not stretch but that may be age.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 10-15-2010, 07:16 PM   #6
MonaxLisa's Avatar
The tab attachments are supposed to be elastic, I replaced all mine (most of the tabs were broken and elastic wasnt elastic-y) so they're all tip top shape. Sounds like hand washing will be the way to go, and then maybe dry on low unless we get a sunny day. Thanks
Old 10-19-2010, 06:59 PM   #7
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
We've washed ours at least three times in our washer. Gentle cycle, Woolite, as soon as they are done, put them in the dryer, on low temp setting. Your tabs should be OK. If you do need any replacements, they are available, either through Airstream, or Camping World.
As soon as it is complete, fold them with the pleats, holding them with either rubber bands, or something to keep them folded with the pleats until you are ready to reinstall them.
It works great, (at least for us), and a lot less than dry cleaning, or buying new ones.
Good luck
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 10-19-2010, 07:34 PM   #8
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
hand washing
I would suggest hand washing if they have age on them. Stupid me washed all mine from my 1976 and they came out in sreads. I had to cut all the tabs (136) and sew in to new ones. It got pricey for the sewing and then to the cleaners to press. Just an opinion.
GAT is offline   Reply With Quote
Old 10-19-2010, 07:53 PM   #9
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Waiting to Escape.... , Somewhere between sanity and insanity ... on the brink of both.
I put my new curtains in my front loader on delicate. On the front curtain one of the rollers came off and I broke one of the plastic tabs when putting it back on. However, all my tabs are really old (some 39 yrs).....
Note - I made my curtains out of a sheets set so that I could wash them at home if needed. My son's allergies don't really agree with dry cleaning...
Nicki
TAC OK-42
Come See Minnie Mouse at the TAC Walt Disney World Fort Wilderness Rally
http://airstreamingdreaming.blogspot.com
"Get busy livin', or get busy dyin'." - The Shawshank Redemption
rebelstand is offline   Reply With Quote
Old 10-19-2010, 08:39 PM   #10
SteveH's Avatar
Common Sense , Texas
I've washed ours a couple of times in the tub, by hand, in cold water, using Oxiclean. Then I put them in the washing machine on the spin cycle only, then hang to dry. They come out just fine.
Regards,
Steve
Old 11-12-2010, 06:05 AM   #11
jwvastine's Avatar
1987 23' Sovereign
Tucson , Arizona
I think a lot depends on the age and the fabric.
Judy
other half of CampAz
Member 4CU
Straw Cottage
jwvastine is offline   Reply With Quote
Old 11-12-2010, 07:28 AM   #12
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The tabs are made from acetel (Delrin) (the non-UV resistant grade). They degrade when exposed to sun. Old or tabs that look a little yellow, should be replaced. The elastic is also not weather resistant and should be replaced at the first sign of stretching. Replacethe top ones with a shorter non- elastic ribbons. The bottom ribbon is not under continual stress and the elastic ribbon can be used there but will degrade with time.
Washing curtains Airperson General Interior Topics 6 06-03-2009 05:53 AM
Argosy curtains & tabs Dan S All Argosy Trailers 5 05-02-2009 06:55 AM
Washing Curtains mustang Upholstery, Blinds, Walls & Interior Finishes 27 09-01-2008 09:02 AM
Worried, help! Walt Stanton Member Introductions 8 04-07-2006 07:30 AM
Washing curtains JOHN L General Interior Topics 7 06-27-2004 02:35 PM
