Old 01-21-2012, 12:07 PM   #1
Olivebranch's Avatar
1964 22' Safari
Omaha , Nebraska
Want to remove original interior paint finish on 64' what is best way?
Have heard that Kleen paint stripper works well. Is that true?
Olivebranch is offline   Reply With Quote
Old 01-21-2012, 01:30 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I found the strongest stuff from Home Depot or lowes (not the stuff that changes color when it's ready) to work just fine. The Citristrip stuff that I had used to remove clear coat on the outside of the 69, and for various projects around the house didn't touch the original zolatone.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-21-2012, 03:44 PM   #3
1964 22' Safari
Omaha , Nebraska
I want to remove some of the zolatone in areas, any suggestions?
Old 01-21-2012, 03:55 PM   #4
goransons's Avatar
1963 22' Safari
The stuff from the hardware store in the large metal cans (regardless of brand) will cut through the zolatone. If you can get the aircraft stripper from a auto paint store, it will be much more expensive but will cut it faster. Generally I found one coat went through the zolatone, and one more coat took the rest and the primer they used below it.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 02-06-2012, 11:38 PM   #5
1978 25' Tradewind
PHX , Arizona
Hey does anyone know if you can just paint over the original vinyl? I have a 77 overlander im refurbishing and I dont have a clue what im doing! ; )
Any help would be soo appreciated!!
Thanks! Colleen
colleengray is offline   Reply With Quote
Old 02-07-2012, 03:01 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The original flexible vinyl laminate on 70's trailers has a plastizier that spews to the surface and gets tacky. If that is your case, you need to clean it off with a detergent cleaner and then sand the surface to get a surface that you can adhere to. Then use a oil based blocking primer like Killz. That can be followed with a latex or oil based paint.
Old 02-08-2012, 11:52 PM   #7
1978 25' Tradewind
PHX , Arizona
Thank you so much! Its a Trade Wind I have not an overlander!
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
We can't locate the original vin# on our 1966 Tradewind Adams Family 1959-69 Tradewind 9 01-14-2012 11:55 PM
How to attain a uniform dull finish. mikeandnora Cleaning, Stripping & Polishing 9 08-04-2011 05:49 AM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
Original External Water Tank fill cap for 69 commander31 Fresh Water Systems 1 02-07-2011 01:38 PM
