Old 08-08-2015, 05:29 PM   #1
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Walls and Ceiling Cleaning
We have a 2000 Bambi with greyish/white carpet like stuff on the walls and ceiling. It is looking pretty dingy, with grime and water stains. Has anyone been successful at cleaning this fabric?
Thanks, Cameron
curnes is offline   Reply With Quote
Old 08-08-2015, 05:49 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I use a commercial cleaner Company Stanley Steamer. It was painless and the job was great.
Old 08-08-2015, 06:31 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I used Oxiclean. Seemed to work about 50/50. I also need to have my house carpets cleaned. Might give Stanley Steamer a call and get both done professionally.
MICHAEL
Old 10-26-2015, 12:36 PM   #4
CanineCoach's Avatar
1999 25' Safari
Inverness , Florida
What if you don't like the stuff?
What can you do if that fuzzy carpet stuff is something you don't like? Is it removable? Can you cover it with something, or do you have to live with it? We just got our 1999 27' Safari and are just starting the project of sprucing it up a bit.
CanineCoach is offline   Reply With Quote
Old 10-27-2015, 08:38 AM   #5
1998 19' Bambi
Parkville , Missouri
We have the same "FUR" in our 98 Bambi. Our carpet cleaner guys cleaned the FUR as they would office parttions and it was amazing how clean and nice the inside is now
MoBambi is offline   Reply With Quote
Old 10-27-2015, 09:38 AM   #6
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
We love our "mouse fur", it acts as an insulator and sound absorber but the black spots are a pain.
Ahab is offline   Reply With Quote
Old 10-27-2015, 09:59 AM   #7
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . 'ditto' on Stanley Steemer, we do NOT like 'mouse fur' I think it's actually called Ozite. . . ! Annual S Steemer call helps tho. . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 10-28-2015, 04:50 AM   #8
1999 25' Safari
Inverness , Florida
Mouse fur
We are going to try the Stanley Steamer route and let you know how it turns out. I get the insulation factor but it will be interesting to see how much dog fur will get permanently woven into the mouse fur😱
Old 10-31-2015, 01:44 PM   #9
1999 25' Safari
Inverness , Florida
Mouse fur saga
We called Stanley steamer and they wouldn't touch it. So we vacuumed it and used the upholstery brush attachment from our carpet cleaner on it, and tried not to get it too wet. It looks a bit better but of course the grey aluminum dust isn,t coming out.
I also have to say welcome to the airstream world for us, guess what we found under the carpet in the rear? But at least the metal frame is good, minimal rust (no idea why picture is upside down on preview)
Old 10-31-2015, 05:05 PM   #10
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Ozite, hull liner, head liner, mouse fur, whatever you'd like to call it - it's polyester fiber.
woolite spray carpet cleaner, a bucket of water and a brush, and an old wet / dry vacuum worked well for us in our 2002 Safari 25C.
though, using a commercial cleaning service sounds really good, too!
ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 10-31-2015, 05:10 PM   #11
AWCHIEF's Avatar
Images: 33
Large photos flip, resize smaller.
MICHAEL
Old 10-31-2015, 05:14 PM   #12
CRH
1995 25' Excella
xxxxx , xxxxxx
I clean my car upholstery and carpet with a Bissell Little Green machine loaded with a 50/50 water and Simple Green mix. It really pulls out the dirt. The water ends up black. I wouldn't hesitate to clean the mouse fur the same way.
CRH is offline   Reply With Quote
Old 10-31-2015, 05:18 PM   #13
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We used oxyclean on ours when it had a very slight stain from a small water leak at one window - it did the trick.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-01-2015, 04:33 AM   #14
1999 25' Safari
Inverness , Florida
Freshing up the ceiling and walls Tim Watts Upholstery, Blinds, Walls & Interior Finishes 5 07-15-2013 12:19 PM
Upholstered ceiling and walls Lumatic Upholstery, Blinds, Walls & Interior Finishes 5 01-15-2013 08:24 AM
Covering uncleanable mouse fur walls and ceiling 3 Dog Nite Upholstery, Blinds, Walls & Interior Finishes 15 11-10-2010 12:13 PM
Leaks in the walls and ceiling urb2165 General Interior Topics 1 10-15-2010 11:25 AM
Replacing the belly and cleaning out the walls? Slik Belly Pans & Banana Wraps 1 10-12-2004 12:20 AM
