Old 12-09-2003, 02:37 PM   #1
danesh's Avatar
Wallpapering
After reading all the messages regarding interior wall refinishing, I noticed that there are no mentions of using walpapers.
Is there a reason that one cannot use wallpapers?
85 sovereign
danesh is offline   Reply With Quote
Old 12-09-2003, 02:40 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Wallpaper
The kitchen area of the '87 as wallpapered about 6 months ago.
Cleaned the original finish with a strong Clorox solution prior to papering.
So far, no problems.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-09-2003, 03:06 PM   #3
I was thinking of doing the same thing in the front and rear areas, only using a fabric thick enough so that the rivets are not too pronounced. Will probably use a contact adhesive.
Dick
Navigator is offline   Reply With Quote
Old 12-09-2003, 03:43 PM   #4
Actually there has been some posts on this, but they may be pretty burried.
I have done, and will do some more papering on the wood partitions. On mine, the "wood" vinyl is solidly attached, so it is just a matter of using vinyl compatible glue.
The inside vinyl coated aluminum would be something more of a challenge, although it seems that it has been done by a few people as well. The rivet heads alone will dissuade me.
Mark
Old 12-10-2003, 07:24 AM   #5
Last year we tried to wallpaper the wood effect vinyl coated bulkhead walls in our Excella. After two days the wallpaper started peeling off. We went to a specialist shop and took advice, and used the recommended sanding and priming methods, and special adhesive, and after three attempts and three wasted days, the paper still came off after a week. We gave up, and spray painted. This has been a great success. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 12-10-2003, 07:49 AM   #6
ke4pk's Avatar
Images: 8
Wink
Wallpaper will not bond to the finished walls unless you use a wall prep solution.
The one we used was "Key Redi-Wall". It is applied directly to the wall with a brush and is ready to paper over in just a few hours.It is a very thin, milky appearing solution and is not messy or any problem to use. It seems to eliminate the gloss from the surface and allow the glue on the paper to bond.
Our first attempt also fell off the wall but when we prepped it with the treatment it is doing fine. Six months and still bonded perfectly.
ke4pk is offline   Reply With Quote
Old 12-16-2003, 12:35 PM   #7
ke4pk
Would you happen to know from the label if your prep was a water based urethane? Mabey they might have called it cyanoacrylate?
Dick
Old 11-05-2004, 02:51 PM   #8
1997 31' Land Yacht
Hixson , Tennessee
Superglue
Originally Posted by Navigator
ke4pk
Dick
Cyanoacrylate is Superglue.
handydan is offline   Reply With Quote
Old 03-28-2008, 02:59 AM   #9
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Put vinyl wall covering on my Argosy three years ago and it's still hanging in there. The trailer came with vinyl wall covering when new and I used a heat gun to remove the old peeling stuff then replaced it. I've also used vinyl wall covering in the Sovereign to cover a cracked end cap. It is still in place after a hard winter. Perhaps it helped to clean the walls with "Marine Clean" and rinse them good to get all the greasy, sticky, whatever that stuff is, off the walls before you cover them. Here are some pics of the Argosy walls. We also covered the wood panel by the door to brighten up the trailer. Also, here's the end cap covering in the Sovereign. Now that was a job to hang it upside down on a curved surface.
ID:	57129   Click image for larger version
ID:	57131   Click image for larger version
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Old 09-24-2008, 10:04 PM   #10
1977 31' Excella 500
portland , Tennessee
wallpaper
what kind of paper did you use and also the adhesive?
netlace is offline   Reply With Quote
Old 06-07-2009, 12:27 PM   #11
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
In your post about wallpapering you mentioned that you cleaned well. I am specifically interested on what method, product you used on the endcap. Both for cleaning prep and for what product (wallpaper) you used. Was it self adhesive type vinyl? Is it still adhered well? It sounds like a great alternative to painting it. I will send you an email too.
Thanks in advance for you help.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 06-07-2009, 01:28 PM   #12
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The original vinyl sheeting, that Airstream used was flexible PVC. That means it contains liquid plasticizers. These start to "spew" after many years and give the sticky surface that people complain about. This 'spewed" degraded plasticizer can and frequently will degrade the adhesive used to bond the new wallpaper to the surface. You need to clean and prime the existing wall with barrier primer to help the new wall paper not peel. I am not sure who makes the best barrier primer for the job.
