Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 07-03-2003, 10:30 PM   #1
overlander76
overlander76's Avatar
Profile:
Wallpaper falling off
Does anybody else have problems with the wallpaper material falling off the walls and other surfaces? All the "wallpaper" with the rough cross hatch pattern is missing in action, leaving the bare plywood and some old glue residue. The other wall covering (see picture) is now getting ready to hit the floor. I guess it was related to heat. How can I stop it? I was thinking about using a spray adhesive on both surfaces and rolling a rubber roller over the outside. Does anybody have a good repair? I'm wondering what kind of adhesive to use?
Thanks for you help...
Name:	above bedweb.jpg
overlander76 is offline   Reply With Quote
Old 07-04-2003, 04:57 AM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Spray adhesives melt at high temperatures.
You could try a non toxic product called VOV (Vinyl over vinyl) wallcovering adhesive available at Home Depot or Paint stores.
First you should 'prime' the bare wood to avoid damage from the water-base adhesive. After that dries apply an even coat of VOV to the primed surface by brush and then reapply the viny by using a plastic wallpaper tool or metal float knife to gently drive out all air and excess glue. If the old vinyl is hard and curly, you may have to use a blow dryer to soften it.
Your next best bet is using a high quality toxic contact cement.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 07-04-2003, 07:32 AM   #3
74Argosy24MH
Profile:  LOST , Hawaii
Peter
Do you know if VOV will work on bare aluminum? I need to find an adhesive pretty quickly.
John
74Argosy24MH is offline   Reply With Quote
Old 07-04-2003, 07:55 AM   #4
PeterH-79MH
Profile:
Images: 63
Re: Peter
John
with an acrylic aluminum primer it would. But think about the temperature/moisture exchange and the VOV being a waterbase product. Doesn't seem like a sound idea for aluminum.
On a side note, John thought that I made a typo writing 'toxic' contact cement. I meant toxic and should have added volatile and flammable. Contact cement fumes are heavier than air and are eager to find a pilot light.........
Falling flourescent light covers Pahaska Electrical - Systems, Generators, Batteries & Solar 4 01-16-2004 05:36 PM
Headliner falling off, looking for a fix ronnie_g Upholstery, Blinds, Walls & Interior Finishes 2 07-31-2003 12:36 PM
The dreaded falling limb!!! Silvertwinkie Our Community 7 07-28-2003 01:13 AM
vintage windows falling out--why? BevnCraig Windows & Screens 13 04-16-2003 06:23 AM
