Old 11-02-2006, 01:28 AM   #1
Wallpaper failure in shower, what to do?
The wallpaper in the shower of my 91 25' excella 1000 is peeling (has peeled)from the top edges of the wall. Appreciate all your expert opinions re: how to repair/replace or what? Thanks
ldetsf is offline   Reply With Quote
Old 11-02-2006, 06:02 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Been there
use trim pieces to secure the paper. shoe molding works well or quarter round. You can buy it in white or simulated wood at HD or Lowes, Cheap too!
smily is offline   Reply With Quote
Old 11-02-2006, 08:26 AM   #3
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
I glued my peeling edge the best I could and then put a nice large bead of caulk on top of that using masking tape to make nice edges. Problem solved.
wacnstac is offline   Reply With Quote
Old 11-02-2006, 09:10 AM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Glue is fine, but if you want more permanant fix, I saw real thin white fiberglass panels at HD they have a nice rasied finish on them.
If they were cut to fit and using liquid nails to hold it up and caulk around the edges it should last for ever.
About $30
I'm doing one wall in my shower with it soon.
'77 Sovereign Intl 31' CB
Old 11-02-2006, 12:48 PM   #5
Thanks for the suggestions. An additional observation: I didn't mention that the top edge has also "shrunk" and can't be forced back to the original edge to re-pin with moulding. As such, if I don't cover it with the Home Depot panels, I'l have to cut off the wrinkled section and leave a bare wall sticky glue surface. If that's the case, any other suggestions?
Old 11-02-2006, 03:02 PM   #6
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Yeah, I think wall paper in the shower IS the problem. I'll be interested to hear how the giberflask panels from Home Dopey work out. The entire bulkhead that hides the pocket door needs to be reinforced and/or redone.
I also want to get rid of all the horizontal molding in the shower running along the outside walls. Any idea on how to remove these and fill the holes? I'm assuming the interior skin is aluminum and if painted with something like POR gloss white would be a dandy shower stall.
-Bernie
bhayden is offline   Reply With Quote
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 11 04-07-2016 06:25 AM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:12 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
Removing the shower stall - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 8 06-16-2002 10:35 AM
