Old 02-12-2004, 09:53 PM   #1
mcneon's Avatar
Wall-to-wall carpet alternative
Anybody ever used carpet squares instead of wall-to-wall carpet in a trailer or motorhome? These are normally used in commercial applications so high-traffic paths or damaged sections can be restored without redoing the whole floor.
It seems that in our mobile environments, where you're liable to track/drip/spill lots of nasty substances, this might be a good alternative. It would be a whole lot easier to install, too, than a full-size cut-to-fit carpet. And, if you stocked a few spare tiles, you could keep the floor looking new just about indefinitely.
One website I've found shows these squares in up to 24x24" size. Those would be big enough to do hallways and such without too many seams or small pieces.
Bob McKeown
Nashville
'74 Argosy motorhome in dire need of carpet (among other things!)
mcneon is offline   Reply With Quote
Old 02-13-2004, 05:47 AM   #2
Am installing wood laminate flooring in my coach.
Will definately use carpet remnants in traffic areas.
Dick
Navigator is offline   Reply With Quote
Old 02-26-2004, 10:52 AM   #3
WBCCI 11067 WDCU
ckeysor's Avatar
1986 25' Sovereign
Atlanta , Georgia
Images: 30
We used tiles from Interface Carpet. They worked wonderfully! My husband installed the carpet himself and it looks beautiful. They are rubber backed so no pad is required and they glued down easily. And, as you pointed out, we have kept an "attic stock" for replacements of worn tiles. You could also do patterns or checkerboard with their products and Interface also has a "walk-off" mat material in tile that I considered using at the door, where the most traffic occurs. It used to be called Huega mat but I think they have a different name for it.
Milliken has a good product as does Shaw. I would highly recommend the use of carpet tile in this type application.
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 02-26-2004, 03:47 PM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I don't know how the tiles stick down, but I hope it's better than the so-called self-adhesive linoleum tiles from Armstrong! They looked great for a few weeks -- until we got temperature fluctuations with the onset of winter! At that point, they shrank so much that they popped off the floor! And, of course, the glue was shot. Great! Nuthin' like good old mastique to glue down linoleum.
Lynn
WBCCI 21043
Old 02-27-2004, 03:45 PM   #5
WBCCI 11067 WDCU
ckeysor's Avatar
1986 25' Sovereign
Atlanta , Georgia
Images: 30
the carpet tiles stick down with double stick tape. The double stick tape is easy to remove if you ever have to replace. The tiles stay down pretty well because they seal each other together.
You have probably seen carpet tiles in office buildings, etc. You really can't tell the difference between tiles and wall to wall.
Chris Keysor
WBCCI 11067
Old 02-27-2004, 08:33 PM   #6
campcollector's Avatar
2003 19' Bambi
Lincoln City , Oregon
Images: 21
Lightbulb Another alternative
http://www.diyfloor.com/group_6568/C...rpet-Tile.html
I saw these today, as a matter of fact at the local Carpet one store. They interlock like a jigsaw puzzle and they were low nap so they could be easily swept or cleaned. I am considering using this when I rip out my factory carpet. The Blue was nice. They had a closout on them for .88 cents a 1ft square.
"No good dent goes unpunished."
campcollector is offline   Reply With Quote
Old 02-29-2004, 10:21 AM   #7
77 R GO C MH's Avatar
1977 28' Argosy 28
Lincoln , Nebraska
I'm curious as to how these squares would work as you were carpeting the coach area.......over the contours of the cowl and around the seat pedestal bases??
77 R GO C MH is offline   Reply With Quote
Old 02-29-2004, 10:47 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I had the same thought. I looked at tiles like these at HD and felt it wouldn't work over the dog house and all, seemed to hard to bend them. They had a pad permanently attached.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-08-2004, 09:08 PM   #9
2005 31' Classic
Gretna , Nebraska
If you do it in the bathroom area, be sure to place a proper seal under the stool which will sit about 5/16" higher than before. My subfloor was entirely rotted out due to this. As a solution, I installed 2 seals under the stool rather than one.
Dwight
16595 is offline   Reply With Quote
Old 11-20-2008, 01:41 PM   #10
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
On my 20' Safari, I installed 30" wide runners with rubber backing and cut them to fit the galley, enterance, bathroom etc. This runner was baught from Home Depot, they come in different pattern and colors the cost is very reasonable under $3/ft. My galley is exactly 30" wide, except in small place had to trim the edge.
Worth looking into.
Zia is offline   Reply With Quote
