Old 02-08-2011, 06:53 PM   #15
1988 25' Excella
Trumbull , Connecticut
Harbor Freight carries a riv-nut that can be installed with a standard pop-rivet gun. They come in6:32, 8:32 and 10:32 sizes. They install just like a pop-rivet.
Regards nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 02-09-2011, 04:38 AM   #16
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by bugnot1 View Post
I am ready to remove all the Airstream window rail rods - and this looks like what I'm looking for. I also want rod pocket window treatment - simple and close to the wall - and washable - not the standard drapery. Those rods look perfect!
Now, where are they from?
bugnot1 - jan
Hi Laura;
How are you going to install a stud in the thin aluminum wall, having no access to the back side of it? "Boatdoc"
boatdoc is offline   Reply With Quote
Old 08-27-2012, 04:50 PM   #17
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
save, remember, retrieve
I saved this thread as I liked the original post about the tube system.
For my trailer, I had to create a bath. It has a shower pan, just not any method to contain the water. I thought I could figure out a way to hang a curtain. The first trip with the curtain idea worked OK, but, a better methods was needed.
My method is 4 hooks that a curtain could hang from. The door side is wood and hooks are no problem. The skin side is aluminum and a good anchor was a challenge. Also, my towel racks are very low and not adequate to dry towels. There is also needs for hanging swim suits and other items.
I recalled this thread and bought a few pieces. It has worked great. I used rivet nuts to anchor the t-bars that hold the rods. I purchased the S hooks and crimped them just enough that they will not come off the bar.
Do not buy the plastic connectors. They were not adequate in maintaining the bar being level if weight was added. I used a wood dowel and epoxy.
Here are a couple photos. You have to imaging the curve of the front end cap. I apologize for the fuzzy photo.
ID:	166921   Click image for larger version
FC7039 is offline   Reply With Quote
