Old 01-17-2005, 05:58 PM   #29
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Talking Velcro
Originally Posted by eljay
Now I am thinking that this might be a good idea even with gauchos. (I pretty much know whose backside is likely to get against the aluminum) Trying to decide how to suspend said wall cushions without rivets or screws in the aluminum...Perhaps hook it to the underside of the shelf behind the gaucho?...?
And I like the looks and potential for that bubble wrap insulation. Egad! You all have created a monster here!
Here is another one for you!
We use this for just about everything...ever seen the guys in the velcro suits try and stick themselves to the wall It can be riveted on or use the industrial stick on type. I don't know what we did before velcro and ziploc baggies
Aaron
WBCCI #XXXX AIR #2495
Old 01-17-2005, 07:11 PM   #30
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Technology-it's a wonderful thing-- thanks for the link and the idea
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 01-18-2005, 07:42 AM   #31
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Wall Warmers
I'm getting a new 22ft CCD and have thought about the wall warmer issue for the bed area. I'll make them out of fabric with a washable fiber fill. Since I have aluminum walls and don't want to mar them I was planning on using suction cups to hang them. One about every two feet should work and will be easily removable to wash, etc.
Old 01-22-2005, 05:13 AM   #32
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Wall cushions
I found a link to some 70's Fabric!
http://www.reprodepotfabrics.com/moderntimes.html
Just need to convince the wife into retro.
balrgn is offline   Reply With Quote
Old 01-29-2005, 03:00 PM   #33
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Talking Wall cushions
After quite a few stops to look at fabrics and searching the web, we found one we could both agree on! Kinda 70-ish paisley print. It measures 75" x 23", spot glued down the foam. Laid out the fabric pulled tight and stapled (1/4") every 4" or 5".
ID:	10253   Click image for larger version
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
Old 01-29-2005, 03:11 PM   #34
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
We don't sew much or well and our 74 had the pads that were in pretty bad shape. We removed the old ones, they were on a board about as heavy as mat board. We then bought 3 comfortors one for port one for starboard and one to cut up and use as wall pads. Just put the material behind the board and glued it in place. The beds covering and the walls matched. Best of all it was easy and inexpensive and made a good looking job.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 01-29-2005, 03:33 PM   #35
MarkE's Avatar
1969 18' Caravel
, Iowa
My '51 AS, with rear twin beds, had no covering on the walls. I knew from past experience that bumping into the cold wall while sleeping does wake me up quickly & abruptly. My fix was to (using the same carpet I installed on the floor) cement carpet to the wall. I ran it up to the bottom of the window frames (a bit higher than the rear window's bottom frame line) in just the bedroom area. Then, I trimmed the top edges with some vinyl wood trim that I purchased, cheaply, at a home-improvement center.
I used artificial wood trim because of it's ability to bend smoothly around the curve of the body and because it matched the color of the original woodwork in my trailer.
After 8 years use, it still looked like new.
'Just another option.
MarkE
WBCCI #4568
MarkE is offline   Reply With Quote
Old 06-20-2005, 08:13 PM   #36
atvmcg's Avatar
1979 23' Safari
Send a message via Yahoo to atvmcg
What kind of material (plywood?) did you use for the panels. I have to replace my wall cushions and the material is some sort of cheap cardboard that's really flimsy. I thought about using Luan or some laminate. How did you fasten the finished panel to the walls?
atvmcg is offline   Reply With Quote
Old 06-21-2005, 10:19 AM   #37
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I just re-wrapped mine. I used some poly felt over the old fabric to give me a nice smooth padded surface, spray glued to the original stuff, and then spray glued the fabric to the poly felt. I reattached the panels with 1/2 inch sheet metal screws that I had painted to blend in with my background fabric color. Mine were originally screwed to the walls.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-21-2005, 11:00 AM   #38
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by thenewkid64
I just re-wrapped mine....I reattached the panels with 1/2 inch sheet metal screws....Mine were originally screwed to the walls.
Ditto the 345 and the 30' Sovereign.
I made an additional panel out of 1/8" "Perf Board" to cover up the area of curb side table I removed - on the Sovereign rear bed room I think I would have had to use something a bit less "stiff" as the corner radii are fairly tight. I think that a plastic corrugated "sign" material (like a heavy cardboard, but plastic) would be perfect for the application.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-21-2005, 11:04 AM   #39
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Luan seems to be about the right thickness. Ours are screwed onto the wall, with wood trim top and bottom.
Old 06-21-2005, 12:09 PM   #40
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I used 1/4" Luan, easy to staple, used an electric stapler to fasten.
http://www.balrgn.com/Airstream/DSC02416.jpg
I did not fasten to the walls, we made them long enough so the mattress holds it tight to the wall
http://www.balrgn.com/Airstream/DSC02421.jpg
www.balrgn.com
Old 06-21-2005, 01:57 PM   #41
atvmcg's Avatar
1979 23' Safari
Sounds good..thanks a lot!
Old 06-21-2005, 09:07 PM   #42
atvmcg's Avatar
1979 23' Safari
I found an auto upholstery supply store..they had the panel board, foam, nice selection of cover materials, adhesives and the chrome trim screw/washers. I paid close to $90 for enough materials to replace both wall cushions.
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 02-12-2010 11:41 AM
Crashed on a wall !!!!!! brunoffrance Exterior Restoration Forum 48 03-18-2008 02:21 PM
What kind of paint for a louver cover for a wall panel heater cindy General Interior Topics 1 09-19-2002 08:38 AM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Where to get new cushions made? Andy R Upholstery, Blinds, Walls & Interior Finishes 8 04-16-2002 01:32 PM
