Old 03-28-2011, 07:13 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Wall Covering Pictures
Not wanting to steal another thread, I thought I would post some pictures of the wall covering we used in our "78" Ambassador. The original vinyl wall covering was buckled by heat, dirty, and not that attractive. We thought about painting, stick on veneer, and then decided on grasscloth. Sherwin Williams had a grasscloth catalog and we found a woven type that we really liked. Application was pretty easy...remove the existing vinyl, over cut the wall covering by about 2", hang on the wall with contact cement, and then trim with X-Acto knife (and many blades). I used the left over wall covering on the panel inserts of the overhead cabinets. It really adds some warmth to our Ambassador.
ID:	125612   Click image for larger version
ID:	125614   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 03-28-2011, 07:54 PM   #2
jal4509's Avatar
1977 23' Safari
Commerce , Texas
Good idea; looks very nice!
Janet & Jim
"You can buy a cheaper burger, but then you gotta eat it." Texas Burger
jal4509 is offline   Reply With Quote
Old 03-28-2011, 09:03 PM   #3
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Wallpaper
Looks terrific! One question: how well does the contact cement survive through wide temperature swings? Such as our Idaho swings of 20-40 degrees daily? That is what is doing in the original vinyl on our '78 Safari (or at least we surmise).
It does look great!
Landshark is offline   Reply With Quote
Old 05-08-2011, 07:29 PM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
It does look great!
Landshark...the wall covering with contact cement has held up through last summers heat and this past winters cold. So far so good!
Old 05-09-2011, 09:39 AM   #5
funhouse's Avatar
2018 23' International
1965 17' Caravel
La La Land , Wisconsin
That is a remarkable difference! Very, Very Nice
funhouse is offline   Reply With Quote
Old 05-12-2011, 06:37 AM   #6
BrockLives's Avatar
1972 29' Ambassador
Currently Camping , Pennsylvania
Very creative and very cool!
BrockLives is offline   Reply With Quote
Old 05-19-2011, 09:25 AM   #7
okiedebi's Avatar
2014 25' FB Flying Cloud
Hillsboro , Texas
That is very nice! We are trying to decide on painting or not, but I do love the grasscloth look...how hard was it to remove the old vinyl? Any particular tips on removal?
Debi
okiedebi is offline   Reply With Quote
Old 05-19-2011, 10:50 AM   #8
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Debi...just grab a corner and pull. Actually I scored it with a knife and pulled it off in strips. Really isn't hard to remove. Make sure you pull it out from under the metal edge banding...that way you can oversize your new wall covering and push it back under the edging. I hit it with a pad sander and it was ready for the grasscloth. We are really pleased with the difference it makes. Good luck!
Need new wall panel ideas? minamyna Upholstery, Blinds, Walls & Interior Finishes 17 08-25-2015 09:21 AM
1960 wall wires blue black red white Lothlorian Lights - Interior & Exterior 2 04-02-2011 02:03 PM
Wall Material & Insulation tr0y Upholstery, Blinds, Walls & Interior Finishes 0 03-20-2011 09:52 AM
Trim to cover gap between wall and floor? adwriter73 Floor Finishes 5 02-20-2011 10:02 PM
shower wall seams - need solution adwriter73 Sinks, Showers & Toilets 4 02-09-2011 10:01 AM
