Old 10-30-2008, 09:59 PM   #1
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
Arrow Wall clock
Is there any special hooks to hang the wall clock. I just acquired a 2007 20' safari and would like to hang a wall clock.
Zia is offline   Reply With Quote
Old 10-30-2008, 10:07 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Congrats on your new Safari, Zia..that's a great model! If you don't want to put a hole in the interior skin to accommodate a hook you may consider a heavy-duty Velcro solution...and if you are afraid that it may fall during travel you can take it down and puat it back up when you arrive....
See you down the road!
TB & Greg and Abbey Schnauzer
#3954
Old 10-30-2008, 10:16 PM   #3
Zia
2007 20' Safari
Irvine , California
wall clock
A good idea, I would prefer a more permanent solution. I have seen ball wall clocks in one Airsteam as a dealer.
Old 10-30-2008, 11:00 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You are probably thinking of the DWR (Design Within Reach) Bambi...it has a Nelson Ball Clock in it... I don't know how they are mounted, but I'll bet an Airstream dealer can tell you. Here's a link for pictures, one of which showing the clock: Airstream, Inc :: Photo Gallery Photo Gallery It is very cool. Good luck!
#3954
Old 10-30-2008, 11:12 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Wall mounted clock.
Hi, Zia; I found a nice clock that my wife and I like and I mounted it with a picture frame hook; The one that I used, looks like two "E's" with the one on the wall faceing upward and the one I mounted to the clock faces downward. Then they snap together and the clock will not fall off. To remove the clock to adjust time or replace the battery, you use a small screw driver to release the locking tab.
Do a search for "Hillman Flush Mount Hanger" #122207" w/spring lock. and you will see what I used.
Name:	My Picture CD 429 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-31-2008, 03:46 PM   #6
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
I just used industrial velcro:
The velcro has not let me down in two years.
Now I'm glad of the velcro:
ROBERTSUNRUS: I really like your clock!
Also, is that thermostat factory standard? I've grown to dislike the one I have (under the Stetson) quite a bit, and thinking of switching it out.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-31-2008, 03:53 PM   #7
2006 19' International CCD
Philadelphia , Pennsylvania
if you are looking for a clock that looks quite similar to the DWR clock, check this out.
Amazon.com: Orbit Wall Clock Silver Balls Modern Design Art: Home & Garden
ericwarren is offline   Reply With Quote
Old 10-31-2008, 07:38 PM   #8
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I used a 3M Command Strip hook. I remove the clock when traveling and store it in the overhead locker.
The nice thing is the hook can be removed without any damage to the wall surface.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 10-31-2008, 09:33 PM   #9
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
We found an approx 12" dia aluminum framed round clock at IKEA. It's lightweight, and has a thermometer and a hygrometer built in on the face. I attached it with velcro strips, but just the hook part, sticking it up on the "mouse fur" wall covering above the dinette seating.
robert claus is offline   Reply With Quote
Old 10-31-2008, 10:00 PM   #10
Salem , Oregon
Images: 18
Attachment 70584
Cheers,
-jd.
Hi, 5cats. we found this aluminum and glass faced clock at Target. I hated the original, manual thermostat so I found this one at Home Depot. It is digital and can be set at the temperature you want and shows the temperature inside of our trailer. I purposely found one that did not have a five or seven day programmer; I felt that it would be useless unless we lived in our trailer. It has two switches on the bottom. One on the left controlls the heater and the one on the right is for air conditioner and not used.
2005 Safari 25-B
Old 11-01-2008, 12:08 AM   #11
Zia
2007 20' Safari
Irvine , California
Thanks TB and Greg. I already baught a ball clock.
Bob your suggestion for the mount is an excellent idea and that is exactly what I was looking for.
Thanks to all the folks for their valuable suggestions, I really appreciate for all the help.
I have another issue with air vent cover over the bed which gives too much light in hte morning. Most of the covers are tranlucent, any idea.
Should I just paint it black?
Old 11-01-2008, 01:48 AM   #12
Salem , Oregon
Images: 18
Vent cover.
Hi, Zia. Like this? I bought this cover kit from Camping World and I trimmed it down in size so I could use the same screws that were in the original trim. I also removed the crank handle and replaced it with a window knob.
Name:	PICT0018 (Large).JPG
ID:	70610   Click image for larger version
Name:	PICT0020 (Large).JPG
Name:	PICT0021 (Large).JPG
ID:	70612   Click image for larger version
Name:	PICT0022 (Large).JPG
2005 Safari 25-B
Old 11-01-2008, 08:26 AM   #13
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Flush mount clock
I am going to mount a 12-volt VDO dash clock from a Porsche on the panel near the stereo. I like the clean look with the chrome trim and the white face. Also comes in the black.
This is for a 2007 19' CDD.
Steamy1 is offline   Reply With Quote
Old 11-01-2008, 12:06 PM   #14
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Great idea
Where did you find the Porsche clock? paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Clock / Thermometer balrgn Electrical - Systems, Generators, Batteries & Solar 20 08-05-2012 09:46 AM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
clock replacement goransons General Interior Topics 0 01-22-2008 10:40 PM
Led Clock DesertRat General Interior Topics 4 05-31-2007 04:09 PM
digital clock sovereign General Appliance Topics 3 08-06-2002 11:21 PM
