Old 02-19-2003, 07:23 PM   #1
Question Vista View Shade Replacemnt
Has anyone replaced the sliding shades on the vista view windows? Mine are cracked and brittle!! Does the paneling around the windows need to come off to access replacing the shade? What material is the paneling made from in a 1971 31' International? Please adivse with any suggestions before I start drilling out the rivets.
Thanks, John
John Sims is offline   Reply With Quote
Old 02-22-2003, 07:29 PM   #2
1990 32' Excella
jonesboro , Arkansas
Cool Vista view
John
I am looking at the service manual for my 73 31'. It says you can take the shade out by removing the rivets out to either side far enough back to allow you to pull the panel down fto pull the shade out without damaging the panels . This should allow you to pull out the shade without removing the frame. Good luck
joel is offline   Reply With Quote
Old 09-07-2003, 04:32 PM   #3
Rick's Avatar
One thing you will see, though, is once the panels are down far enough to expose the window frame, is the frame is screwed together on the top. On my '68 Overlander, there are (were) three screws per side on the top rail, and I had to remove the top rail before the shade could be removed. I replaced the shade with a thin piece of pvc plastic and a glued-on finger pull. One side's done, now I've got to do the other!
Rick is offline   Reply With Quote
Vista View window repair/replacement 83Excella Windows & Screens 16 03-05-2021 08:03 PM
1973 Vista View Restoration Tripp Windows & Screens 12 11-17-2011 12:11 AM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 08:23 AM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
