Old 07-18-2007, 06:44 PM   #1
jerome , Michigan
Vinyl trim
Does anyone have a line on the 70's vinyl trim that went around the windows? It actually covered the edge of the wall board. It looks similar to the old door moldings that went on the back edge of your car doors except it is white instead of black. See bottom of picture. Side trim is there (hard to see), bottom is missing.
Aaron
metalhead is offline   Reply With Quote
Old 07-18-2007, 06:47 PM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
J trim
Hello .. It can be ordered thru any A/S dealer... also you can get some J trim at Home Depot... we got ours from Jackson Center and I am going to get some white from Home Depot also..
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-18-2007, 06:52 PM   #3
jerome , Michigan
That was easy enough. Thanks alot Happycampers .
Old 07-18-2007, 06:55 PM   #4
1979 30' Argosy
You are most welcome..
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 07-18-2007, 07:33 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
It looks like the J-trim common in Argosy trailers too. I used OASIS R.V. CENTER, INC. - Home -- call their toll-free and talk to their parts dept. They are very savvy over the phone, their shipping is inexpensive, and I'll bet you could have the product in your hand within 5-6 days. You will need to use side cutters to nip the longer side of the J-trim every 1/4-1/2" to make a curve that sharp I would say! You'll need to remove all rivets and reinstall new pop rivets -- available locally for you -- be sure to use all-aluminum pop rivets, not those with the steel pulls.
5 meter Langford Nahanni
Old 07-18-2007, 08:20 PM   #6
SLVRSRFR's Avatar
Orange city , Florida
Send a message via AIM to SLVRSRFR
you should see mine. It is brown and cracking away! I will need to get ahold of lots of it when I can afford my next phase of restoration... thanks for the info...
SLVRSRFR is offline   Reply With Quote
Old 07-18-2007, 11:01 PM   #7
Aaron
Attachment 41445
We have plenty of that material in stock, that is not vinyl.
A vinyl replacement will do the same thing that the original material did, namely shrink and fail in short order.
Old 07-23-2007, 10:47 AM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Andy, do you have a pic of your window trim?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-23-2007, 11:27 AM   #9
Click on the following to see that photo.
http://www.inlandrv.com/parts/71571-vistatrim.jpg
Old 07-23-2007, 11:44 AM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Andy. Looks like they can be painted, too!
1958 Overlander
4CU 1st VP
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 06:56 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
Grades of vinyl... Andy R Floor Finishes 2 05-31-2002 11:47 AM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
