Old 05-14-2006, 08:26 PM   #1
1966 26' Overlander
Houston , Texas
vinyl repaint
I have a mid 60's AS that I has been closed up for years in the hot south Texas sun. The vinyl covering on the interior walls has become "sticky" and discolored from time and very hot temps. I don't want to remove it if I can simply paint over it. Does anyone have any suggestions? The trailer has survived in spite of almost no maintence for 30 or more years and I have decided to revamp the interior for use. Thanks for replys.Ted
ted368 is offline   Reply With Quote
Old 05-14-2006, 09:31 PM   #2
Mad1
1989 29' Excella
Dallas , Texas
Prime with Kilz original (xylene based ) primer then any paint will stick to it.
madrone is offline   Reply With Quote
Old 05-15-2006, 04:25 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Vinyl plasticizer spewing
I think you should remove the sticky plasticizer before you start painting. It is actually a partially crosslinked liquid that was added to the vinyl to make it flexible. After many years the compound degrades and the plasticizer leaches to the surface. There are a number of cleaning products that will dissolve it including "Spray Nine". Then you can paint over it with the solvent based primer and not have the plasticizer dissolve in it and wreck the primer.
Old 05-15-2006, 07:02 AM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums and congratulations on your purchase. Many of us have purchased a similar Airstream and know what you are going through. Sad so many people just left them sit with out using them. Sticky walls is a subject like polishing there are many ideas and suggestions. This is a good way for you to learn how to use the search function. Punch "search" and put in the word "sticky" you will get several hundred replies. One good reply is below. Good luck to you and again welcome.
http://www.airforums.com/forum...ghlight=sticky
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-15-2006, 09:53 AM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I've read several of the painting threads and still have a basic question that has yet to be answered.
There are various methods to paint the vinyl walls. They range from the fairly simple "kilz and latex" to complicated spray on layers using various cleaning methods and primers and finish coats, etc, etc.
The question is this. Who has had long term acceptable results with any of the methods. Say, four or five years? I'm guessing that if not done properly, a few years down the road all of that vinyl will have to removed from the interior wall panels.
Anybody?
www.nesa.org
Air No. 6427
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 01:35 AM
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 06:56 PM
vinyl wallcovering seniors2 Upholstery, Blinds, Walls & Interior Finishes 2 12-23-2002 08:14 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
Grades of vinyl... Andy R Floor Finishes 2 05-31-2002 11:47 AM
