Old 03-30-2014, 07:09 AM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
Vintage curtain rod trouble
I have the original curtain rods in my 1961 bambi and I would like to keep them. I ordered new plastic slides but they seem to stick just like the old ones. Any tricks to making the slides move sling the track?Click image for larger version
Name:	ImageUploadedByAirstream Forums1396184946.481845.jpg
1961 Bambi
www.bambiairstream.com
thinktankair is offline   Reply With Quote
Old 03-30-2014, 08:07 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I used a small squirt of spray silicone lub spray. I also use it in the awning channel mount and the Zip Dee arms.
Old 04-17-2014, 12:14 PM   #3
64Lincoln's Avatar
1964 22' Safari
1964 22' Safari
Sacramento , California
Have your tracks been painted? Many times this is the cause of all problems. If so, you will have to remove the paint. I've spent a lot of time sanding my tracks back to smoothness. It definitely helps. WD-40 can only do so much when there are gobs of paint in the way.
64Lincoln is offline   Reply With Quote
Old 04-17-2014, 12:56 PM   #4
1961 16' Bambi
Thanks so much. I will check for paint. The silicone seemed to work great!
Shower Curtain Rod '68 Safari? gc24 1966 - 1968 Safari 4 02-08-2022 08:11 PM
Front curtain rod? CampUnger Upholstery, Blinds, Walls & Interior Finishes 8 05-26-2011 11:59 AM
69 Sovereign - Shower Curtain Rod or ??? tdoescher Sinks, Showers & Toilets 3 08-22-2009 03:08 AM
HHOT ROD / Lightning Rod ROBERTSUNRUS Water Heaters, Filters & Pumps 4 07-11-2009 05:03 PM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 11:46 AM
