Old 04-28-2010, 10:08 AM   #1
1972 25' Tradewind
Summerfield , North Carolina
Question Using Latex on 74 Trade Wind interior walls?
I am refurbishing my 1974 Trade Wind and was wondering if anyone has had experience using latex paint on the pvc coated walls (mine aren't Zolatone)? My specific concern is bonding ability, longevity, and look. I assume that cleaning, light sanding, TSP rub-down and a primer that bonds to the original wall covering would prep the walls, however, I'm not sure if latex might be a good choice or a problem. If anyone can shed some light on this I would be great full! Thanks.
todanielm is offline   Reply With Quote
Old 04-28-2010, 10:15 AM   #2
1986 31' Sovereign
Miami , Florida
If you pop down to the interior forum you'll find lots of sage advice. One of the more thorough (and long) threads is:
http://www.airforums.com/forums/f39/...cky-55249.html
Lots of ideas there.
Good luck,
mike
Old 05-23-2010, 07:51 PM   #3
1979 31' Excella 500
mckinney , Texas
DIY Restoration
Hi There, Do It Yourself or DIY Channel did a complete restoration on an AS, and on the internet there are about 25 6 minute videos that show restoration tips. The site is at www.usedairstream.com/airstream-videos/airstream-restoration/1970-airstream-overlander-yacht-video-2/. Click on videos. It has step by step instructions on painting the interior with the correct paint to use. It has a lot of great stuff. Eric
Further99 is offline   Reply With Quote
Old 05-23-2010, 09:36 PM   #4
RichHog's Avatar
1972 23' Safari
Houston , Texas
of course everything looks easier on TV. Fortunate that my interior walls are still in good shape so I have a few years to go before wall painting. But did redo the plastic laminate with wood veneer. A great improvement
RichHog is offline   Reply With Quote
Old 05-23-2010, 10:55 PM   #5
light sanding.
Light sanding. "No way".
Heavy sanding with 120 to 150 grit sandpaper.
Sanding, not scuffing is the key.
Old 05-24-2010, 08:24 AM   #6
funkill's Avatar
Tucson , AZ
Images: 27
Todanielm ... I started that tacky thread referenced above ... and have finally eliminated my tackiness. I wouldn't want to go through it again. Here's a more *concise* thread that is worth a read before you start your job!
http://www.airforums.com/forums/f39/...ors-62392.html
good luck to you!
Laura
funkill is offline   Reply With Quote
1968 Tradewind: rearranging the interior: rear bed / bath IndyAnne 1959-69 Tradewind 126 01-30-2014 07:27 AM
1968 Trade Wind 24' No interior lights? cheer2u1950 Batteries, Univolts, Converters & Inverters 5 09-14-2009 10:35 AM
Trade Wind A/C Help mikesplace Furnaces, Heaters, Fireplaces & Air Conditioning 20 07-17-2009 09:48 AM
Need help on trade wind mercury7 1959-69 Tradewind 57 10-27-2006 07:38 PM
'61 Trade Wind DiMi Member Introductions 7 08-01-2006 04:00 PM
