Old 03-20-2015, 12:56 PM   #1
To Rip Off Walls Or Not To Rip Off Walls...
My wife and I are outfitting 31 foot 1979 sovereign. We have the crappy custom furniture someone tried to put in there ripped out and some of the floor ripped out because it was rotted due to a small leak.
We are now trying to figure out if we should take off all of the skin on the inside because we're not sure of the condition of the gas/water pipes or electrical wires.
So I feel like I'm stuck in a dilemma on the one hand it would save a ton of work now not to have to take off all of the inside skins but part of me says gut everything to see what this baby's really made of and rewire the whole thing as well as fix any small leaks.
Any help would be awesome... planning on totally redoing the floors anyways so it seems like we have to take everything out. Just trying to determine if that 'everything' also means the interior metal skin walls/ceiling.
Thanks!
belikethefox is offline   Reply With Quote
Old 03-20-2015, 12:58 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
if you are up to the task you could certainly make it your own. But its not a necessity..
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-20-2015, 01:20 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You are standing on a very famous slippery slope. It starts with "as long as I am here..."
The only plumbing that is behind your inner skins should be some of the venting pipes for the tanks, so you should not need to worry about water or waste leaks behind the wall.
The gas lines definitely should not be traveling behind the skins if they are, then some PO has gotten creative/stupid.
The wiring is all behind the walls, but you can check it without tearing the whole trailer apart. Get yourself a decent Volt-ohm meter, and disconnect your trailer from any power supplies (AC power and the batteries), so that every circuit should appear open. If you check each line to mass and see no continuity, then you can feel pretty confident that no wire has had its insulation rubbed through and is shorted to ground. Next, you can check each circuit for continuity from, for instance, the outlet to the circuit box. If you have continuity, then you are good. Finally, check and make sure your AC wiring is not made of aluminum (it should be solid copper). If you have no short to ground, continuity, and copper wiring, then I would say you have no reason to tear out your wiring.
With your floor repairs, the first question is, is your floor rot so bad that you will be replacing entire sheets of plywood, or is it small enough that you can patch it? If you are going to have to go under the wall with your floor repairs, you will have to pull off at least some of the interior skins to get at the heads of elevator bolts and screws that hold the shell to the plywood. This will give you a glance at what is inside the wall. You will likely find old stanky fiberglass insulation, probably with an ancient mouse colony dug into it. If you are lucky, there will be nests and snake skins to go with it, and certainly some mummified mouse corpses. The slope gets steeper from here, as you will either decide you might as well do a shell-off (add 6 months to 1 year to your project), or at least you will be so disgusted that you will want to pull off all the skins and replace all the insulation. Then you will convince youself the wiring may as well be replaced, and you can just add a few more months to the project.
On the other hand, if you don't have to go under walls to do floor repairs (you wish you could be that lucky), the trailer doesn't reek of mouse infestation, and your electrical system checks out as described above, then leave Pandora's Box closed and save yourself a couple years!
good luck!
Old 03-20-2015, 01:31 PM   #4
You are a legend! Thank you!!
Please Help with Suburban NT-30M Furnace before I rip off all my skin. berea777 Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-06-2013 05:55 PM
Dometic Rip-Off rickandsandi Refrigerators 28 02-25-2013 09:21 AM
Dented skin repair from awning rip-off givememoreli Ribs, Skins & Rivets 3 07-18-2005 06:28 PM
