Old 04-07-2007, 01:34 PM   #43
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Originally Posted by Safari Tim
That looks sharp Doug.
I assume you're putting it across the front. So it will have to be away from the front about 16" or so. That would actually work out nicely for the recliner. I also like the drop down table in the center.
I'd like to see some inside shots of your Ambassador! (Do you have a fold away bunk? I'm looking for detailed photos and measurements so I can build one
If I use it it will fit across the front. We have no one that will be travelling with us so we don't need extra beds. Anyway I can sleep in the recliner at home just fine. I am way behind you on finishing as we took off for the winter and headed south. I've got 2 finished trailers so I can take time out from this one . We don't have bunks, you'll have to see Rob for that. He just brought home his remade bunks. Check out his blog.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 04-11-2007, 12:29 PM   #44
kincaidjesse's Avatar
1966 28' Ambassador
Here , Illinois
Hello:
This is just a short test. Yesterday, nothing went through. More if it does!
kincaidjesse is offline   Reply With Quote
Old 04-11-2007, 12:38 PM   #45
1966 28' Ambassador
Here , Illinois
OK. Working. Don't know what I did yesterday.
I think you can have both a couch and a bed. I have a 1966 Ambassador and I had to replace the couch/bed. The area looks like yours but the cabinets (bed frame) and shelf under the window were present.
I had a mattress custom made to fit the area for about $120. Fortunately, I had the frames for the arm rests on the ends - they were just bedraggled. So, I purchased heavy duty oil cloth (marine quality) from JoAnne's Fabrics, took the mattress, the arm rests and a heavy foam rectangle for the back rest to an Amish boat canvas upholsterer and had them upholster all of that, plus the mattress for the 2nd bed. It just wipes off - no dirt, no pet fur. The table on the end which folds up was present.
I have photos for you, if you like. I haven't figured out how to insert them.
Old 04-11-2007, 12:47 PM   #46
1966 28' Ambassador
Here , Illinois
One more thought. I would not recommend foam. Since the Hurricane, the price of foam has shot through the roof. Mattress factories, like The Denver Mattress Factory, etc. actually do a great custom job for a fraction of the price of foam. Foam needs to be pretty thick to hold up to pressure and weight. I will try to figure out photo uploads or I could email mine if they would help at all. Good luck!
Old 04-16-2007, 05:54 AM   #47
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Nearly Finished Dinette Pics
Okay, probably last pic of the dinette before I post project completion pics under my "photos" section.
Finally finished trimming out all the frames as well as adding a small piece of molding around the top to support the table in the bed position. Stain and finish will wait till after the Springstream Rally this weekend.
Tables were constructed with 1/4" luan with a 1" plywood frame underneath. (each table weighs 11 lbs). They will be clasped together using window latches.
Foam is "wrapped" for now. My wife will sew covers with piping later this spring.
Name:	Dinette 005 webcopy.jpg
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 03-25-2009, 02:51 PM   #48
yuma , Arizona
my brother in law and myself were just talking about doing something like this. you have made up our minds, gonna do both trailers. I have four kids (7 and below) and there is absolutely no reason to have that single couch. we don't use the dinette and the sliding cabinet is a joke. plus the table going down to make a large bed is great, lets us get rid of the air mattress that they have to use on the floor.
did you run into any problems? I was curious as to how you anchored it to your walls (if you did) Once we get going will update you on your "pre patent" idea.
thanks,!
themunks is offline   Reply With Quote
Couch option Pahaska 2002 - 2005 International 10 07-14-2005 12:05 AM
New Int'l Floorplan RoadKingMoe 2002 - 2005 International 41 03-02-2003 05:10 PM
Questions about the 2003 International. Would you buy again/fair price. Debbie 2002 - 2005 International 29 11-07-2002 04:11 PM
Will this couch fit my trailer?? JohnGalt48 General Interior Topics 4 08-07-2002 06:38 PM
front couch for 31 soverign center bath jim c taylor General Interior Topics 0 04-12-2002 03:58 PM
