Old 06-13-2009, 10:56 PM   #1
coairstream's Avatar
1964 22' Safari
Denver , Colorado
Tambour vs Custom Sliding Doors
I have a 1972 Trade Wind 25ft and for the most part the tambor is good, but I dont want to go through the trouble of trying to repair the broken/seperated pieces with fiberglass backing. I watched a youtube video today that showed a newer Bambi and it had what looked like sliding frosted doors. I think I could have custom plexi glass ones made and just install a track. Any thoughts? Also How much should I expect to get for the tambor, both the good and bad?
coairstream is offline   Reply With Quote
Old 06-14-2009, 02:43 AM   #2
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Welcome to the forums!
The price people pay for tambour seems to vary. A lot of people offer it free to other forum members for the cost of packing/shipping. Kind of a pay it forward. Others have asked $25 for the larger tambour in good shape. You can just list a best offer price also. If you want to either offer for free or a price you can do that it the classified section of the forums. Good luck with your new doors. Be sure to post photos, as we all would love to see your end results. Feel free to show your work in progress too, as misery loves company
Airstream Trailer & Airstream Motorhome Classifieds - Main Index - Powered by PhotoPost Classifieds
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 06-14-2009, 09:32 AM   #3
1964 22' Safari
Denver , Colorado
Thanks Mary!!! One more question. I just joined last night and put up several questions. Is there an easy way to know if someone ansered them or do you just need to go back to your posting and check?
Thank you,
Cody
Old 06-14-2009, 06:24 PM   #4
Maryw164's Avatar
1972 31' Sovereign
Cody,
I sent you an email with some hints. Check it out.
Mary
Happy Trailering !
Old 06-14-2009, 07:39 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The sliding cabinet doors are in the CCD Airstreams, and are similar in principle to the sliding doors in the 1960's trailers. You could probably go to your local home improvement store to get the tracks, and maybe some sheets of white, smoke, or (insert your favorite color) Lexan for the sliding doors.
Old 06-18-2009, 09:25 PM   #6
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Tambour in 72 Tradewind
I recently replaced the tambour in my 72 Tradewind below the sink. It's the long vertical section about 3' long 2 ft wide. A PO removed the section and but in a metal sliding door that didn't slide very bell and had a bend in the center.
The new tambour was maple and then stained with Minwax Provncial211 stain. It matches the original laminate very well and looks great, makes the kitchen look complete. Also replaced some of the fake wood laminate with real veneers in the front and oh boy it looks so much better.
RichHog is offline   Reply With Quote
Old 06-18-2009, 09:37 PM   #7
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
We went with custom sliding pocket doors!
Name:	New Interior 013.jpg
FLYNCLD is offline   Reply With Quote
Old 06-18-2009, 09:58 PM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I replaced my damaged and missing tambour with new tambour stained with Minwax Dark Walnut (2716). I think it's a pretty good match.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-18-2009, 10:03 PM   #9
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Used Minwax Provential 211 on Maple tambour. It's a great match too.
Old 06-18-2009, 10:10 PM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Pics???
1958 Overlander
4CU 1st VP
Old 06-25-2009, 07:40 AM   #11
Mexray's Avatar
1978 28' Ambassador
Morada , California
Mike, where did you get your new tambour? Ours is mostly shot too...
Did you have to remove the cabinets, or could you replace it wheil in place?
Thanks...
Ray
Ray & Pat; Morada, CA
Old 06-25-2009, 10:29 AM   #12
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks...
Ray
Good question, Ray. You can buy the tambour at several locations but Tape Ease and Inland RV come immediately to mind. Inland RV also sells the pull handles. As for replacement, it's pretty easy. The old and new tambour can be replaced with the overhead lockers still in place. You only need to remove one of the spiral tracks and out everthing comes.
1958 Overlander
4CU 1st VP
Old 06-26-2009, 01:42 AM   #13
Maryw164's Avatar
1972 31' Sovereign
panel type?
Looks great! What did you use to recover/finish the walls/partions, etc. It looks like a paneling of sorts, but with an interesting texture.
We have the ugly dark walnut panels, we'd like to eventually replace with something lighter.
Thanks, Mary
Happy Trailering !
Old 06-26-2009, 11:00 PM   #14
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Real Wood over old laminate
We used 1/4 Oak panels with the Minwax stain to replace the end panel and then used Oak veneers glued to the old laminate. Then the new maple tamour panel below the sink matches the new wood well. Plan to slowly replace the rest of the plastic over time. (Picture was before the Tambour replacement)
Upper cabinet sliding doors Grand Master Cabinets, Counter Tops & Furnishings 12 01-08-2010 09:00 PM
cabinet sliding doors Jim Denman Cabinets, Counter Tops & Furnishings 4 02-19-2009 08:01 PM
Awful sliding doors kooblekidz Upholstery, Blinds, Walls & Interior Finishes 6 11-05-2007 07:58 PM
Sliding Pantry Doors Tikiman Cabinets, Counter Tops & Furnishings 1 11-07-2005 07:17 PM
cabinet tambour not sliding ravholette Cabinets, Counter Tops & Furnishings 2 04-04-2005 07:51 PM
