Old 01-16-2011, 06:36 PM   #1
vhariable's Avatar
1967 30' Sovereign
1977 31' Sovereign
1988 29' Excella
Abilene , Texas
Stripping Walls Advice (while on or off)
I am working through a shell on restore of our '67 Sovereign and am at the point of needing to remove the inner skin. I would like to strip the walls and will be repainting some areas and polishing other areas. My question is this: should I strip the walls while they are still attached or individually once I have them removed?
'67, '77, & '88 Restoration Projects
http://projectairstream.com
vhariable is offline   Reply With Quote
Old 01-16-2011, 06:43 PM   #2
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Never done it my self but it seems the job would be easier if you did as much work on the panels as possible while they are attached. Do the small hidden areas once removed. Having the panels in place will elimiate the problem of holding them steady on a work bench and minimize the chance you might bend them during the rigors of stripping, polishing. Just my opinion.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 01-16-2011, 06:51 PM   #3
vhariable's Avatar
1967 30' Sovereign
1977 31' Sovereign
1988 29' Excella
Abilene , Texas
That was my thought also, but also was thinking that if they could be stripped individually outside in the open air that the process might not be as smelly.
Old 01-16-2011, 06:55 PM   #4
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Many on the forum recommend Citrix stripper. I have used it my self for a re do of kitchen cabinets and the smell was not bad. Plenty of ventilation would be good - windows open and fan on far end drawing air out.
Air Cid
Reese WD Hitch
Old 01-16-2011, 06:58 PM   #5
vhariable's Avatar
1967 30' Sovereign
1977 31' Sovereign
1988 29' Excella
Abilene , Texas
Where can Citrix be found? Thank you for the information.
Old 01-16-2011, 07:03 PM   #6
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
If you don't mind some neck aches, you can do it on, but keep in mind its messy, very very messy. tarping things is somewhat effective but the strippers that do a good job on the paint will also eat many plastics that tarps are made of.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-16-2011, 07:08 PM   #7
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
I dont know what is the best way. I used removall 220, similar to Citrix (I think). I got it from vintagetrailersupply.com It has no fumes, it is enviromentally safe and it does not burn your skin. However, it did only a so so job on taking off the zolatone. I painted it on while the panels were up and then powerwashed off the stripper. A hugh mess!!! I took the panels off and plan on finishing the cleaning out on the grass with other strippers.
Good luck
nick6930 is offline   Reply With Quote
Old 01-16-2011, 07:16 PM   #8
MDSilverado's Avatar
1977 31' Sovereign
Severna Park , Maryland
I stripped the inside of my 77 Sovereign...now I know it is vinyl not Zolatone, but I highly suggest you strip the panels in place. I stripped some on the the garage floor and found it much more difficult than stripping in place!
MDSilverado is offline   Reply With Quote
Old 01-16-2011, 07:52 PM   #9
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Purchased mine at home depot - but other big box stores may have it too
Air Cid
Reese WD Hitch
Old 01-16-2011, 08:00 PM   #10
vhariable's Avatar
1967 30' Sovereign
1977 31' Sovereign
1988 29' Excella
Abilene , Texas
I really appreciate everyone sharing their experiences! I think I will go for trying to get as much off as possible while the panels are still in place and then finishing them up once they are removed. Will go get some Citrix tomorrow and give it a try.
Old 01-16-2011, 09:08 PM   #11
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
67 Interior
If your 67 is like mine it has vinyl clad aluminum walls. Is this what you are talking about stripping? I have read here on the forum that stripping that vinyl is one heck of a job. I'm probably going to paint some and replace some with new aluminum.
SilverHoot is offline   Reply With Quote
Old 01-17-2011, 03:33 PM   #12
1977 31' Sovereign
If you are stripping vinyl I dont reccomend Citrix. It's just not strong enough. You will need to use the bad stuff (cant remember the name but have a can at home in the garage) and get yourself a organic respirator, gloves, goggles, and old clothes.
Old 01-17-2011, 09:11 PM   #13
vhariable's Avatar
1967 30' Sovereign
1977 31' Sovereign
1988 29' Excella
Abilene , Texas
I tried out a small test area today and removing this vinyl is VERY easy! I used Jasco Premium Paint and Epoxy Remover and placed some plastic wrap over the test area for 20 minutes. I then used a plastic scraper to poke a hole into the vinyl and then pulled it away with my hands in one big piece. The Jasco stripper had very little smell in a well ventilated area. What you see in the pictures is just that and I haven't even used any mineral spirits yet as it looks to have removed most of the adhesive as well.
I found the Jasco and plastic wrap recommendations on this thread which turned out to be invaluable. http://www.airforums.com/forums/f39/...alls-2625.html
ID:	119572   Click image for larger version
Old 01-24-2011, 02:40 PM   #14
vhariable's Avatar
1967 30' Sovereign
1977 31' Sovereign
1988 29' Excella
Abilene , Texas
UPDATE: I have tried many variations of applying the stripper including making sure there is direct heat, cover with plastic wrap, etc. The real key for me has been just simply making sure there are two really good coats of the stripper. When it is working and I apply the second coat a gummy layer starts to appear as I am brushing on the second coat. I typically brush on a coat and then come right back when I am done with the first coat and apply a second coat. This works each time and even in 50 degree ambient temperatures.
Advice on camping the Canadian Rockies Pacerized On The Road... 43 02-17-2011 07:53 AM
Looked at airstreams today.. Advice needed. mikeandnora Buyer Guidelines 45 02-09-2011 11:27 PM
How much tongue weight? And other questions. MonaxLisa Hitches, Couplers & Balls 15 01-12-2011 02:43 PM
Advice on towing with a Pacifica tslanier Tow Vehicles 7 03-10-2008 02:55 PM
