Old 07-16-2014, 11:22 AM   #71
1971 31' Sovereign
Lake Minnetonka , Minnesota
Quick question, why not just take down the panels, and make new aluminum panels with outlines from the originals? Wouldn't that be more time and cost efficient?
bakes is offline   Reply With Quote
Old 08-13-2014, 06:47 AM   #72
Dustycowgirl's Avatar
1968 26' Overlander
Ocean isle beach , North Carolina
Just started on a test small piece applying the jasco wish me luck wish it was a little cooler when I started this process not summer all these long clothes are no fun
Dustycowgirl is offline   Reply With Quote
Old 08-13-2014, 07:45 AM   #73
1968 26' Overlander
Name:	ImageUploadedByAirstream Forums1407937469.113747.jpg
Here is what it looked like once stipped and washed. Still a lil aged looking thoughts? Is that cool patenna for the walls kinda like aged copper but aged silver or not I'm going for the rustic look inside anyway ?
Old 08-13-2014, 08:03 AM   #74
1967 26' Overlander
Bugtussel , Oklahoma
It looks beyond rustic to me. I would describe it as "post apocalyptic" which would be awesome if that's what your going for.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 08-13-2014, 08:11 AM   #75
1968 26' Overlander
I am going to go ahead and do the rest an if I don't like it I'll polish it maybe? Anyone have experience polishing it
Old 08-13-2014, 10:06 AM   #76
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
Originally Posted by Dustycowgirl View Post
Attachment 218983
Are you sure all of the adhesive is off? I did a test strip, that looked like that, then used lacquer thinner and a scrub brush, which took off some of the yellow/brown color.
Mike
Bauxter is offline   Reply With Quote
Old 08-13-2014, 10:35 AM   #77
1968 26' Overlander
Gotcha I can tell it's adhesive residue but the stripper doesn't seem to be taking it off I also noticed that when I moved the piece I was working on to the shade it to like twice as long to work it's magic
Old 08-13-2014, 10:42 AM   #78
1968 26' Overlander
Name:	ImageUploadedByAirstream Forums1407948122.437197.jpg
Name:	ImageUploadedByAirstream Forums1407948035.766247.jpg
ID:	218989   Click image for larger version
Name:	ImageUploadedByAirstream Forums1407948058.198332.jpg
Old 08-13-2014, 12:12 PM   #79
Airhead in An Airstream
SCopp's Avatar
1955 26' Cruiser Overlander
Longview , Texas
Images: 58
Takes lots of elbow grease
I stripped the nasty old vinyl off the walls in our trailer. Once the vinyl was off it took 2 or 3 applications of stripper and 0000 steel wool to gently remove the adhesive. I then wiped it down with citrus cleaner and paper towels.
We wanted to have polished aluminum walls. The interior aluminum is not the same as the exterior and will take many more hours to polish. I used the Nuvite products and wool pads to polish the walls.
Good luck! You will have Popeye arms when you are done!
Susan
SCopp is offline   Reply With Quote
Old 08-13-2014, 04:03 PM   #80
1968 26' Overlander
I want the interior walls to end up shiny but not so much that they are a mirror finish. Just curious did the steel wool scratch the aluminum Bc it did when I tried it on a test piece
Old 08-13-2014, 05:27 PM   #81
SCopp's Avatar
Longview , Texas
Images: 58
No, I used 0000 steel wool (very very fine) and a very light touch - just enough to pick up the glue.
Old 08-14-2014, 12:31 PM   #82
1968 26' Overlander
This is taking a while... Anyone know of a power tool or drill attachment to help w this? Click image for larger version
Name:	ImageUploadedByAirstream Forums1408041064.598685.jpg
ID:	219026 also had to use more than a light touch to get it off so now it has a texture for better or worse?
Old 08-14-2014, 12:46 PM   #83
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
I would use a different chemical after the vinyl comes off. The laquer thinner and a small brush worked for me, but there is also an adhesive remover that the big box stores sell.
mk
Old 09-22-2014, 03:19 PM   #84
Question for all those who have exposed and left the aluminum walls. How do the walls react with extreme temperatures... does the trailer stay cool when really hot outside... warm when cold outside... does it create condensation inside and become a rainforest?
Trixella is offline   Reply With Quote
sticky interior walls sovereign Upholstery, Blinds, Walls & Interior Finishes 64 08-14-2009 10:18 AM
Zolatone walls Rob Upholstery, Blinds, Walls & Interior Finishes 19 08-05-2009 06:54 PM
Shower walls, what to do? myboyburt General Interior Topics 1 04-16-2004 03:54 PM
getting behind the walls... Chuck General Interior Topics 14 07-11-2002 12:20 PM
