Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Upholstery, Blinds, Walls & Interior Finishes
Old 09-18-2009, 06:33 PM   #1
Profile:  1973 21' Globetrotter
Strathroy , Ontario
We have about 75% done- we took the 'ceiling' panel off- it was only a few rivets and then it slid out. The walls and even the rivet look clean- My husband tried car polish on a small area- it gave it a litle shine and hopefully will prevent oxidation. My parents 2008 is aluminum inside....wonder if it has a coating??????
***Words of advice- find plastic 'scrapers'- anything metal leaves marks. We did use a razor blade to trim around window frames. I will go and take some pictures right now!
C
catmoore is offline   Reply With Quote
Old 09-21-2009, 10:32 AM   #2
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
There is no distribution by Surf-Pro for the 'Glue Buster" in the USA - its a Canada only product.
The MSDS (http://www.surf-pro.ca/english/media/glue_buster.pdf) lists Methylene chloride (>60%) and Methanol (5-10%) as hazardous ingredients; the remaining components would be gel agents and skin forming compounds to reduce evaporation, etc.
Methylene chloride is hard to find in the States, usually it is a minor ingredient but there are a few exceptions, I've got it as sole active ingredient in an automotive gasket remover aerosol that I will try out.
There are also some of the paint strippers that still have it as the major solvent - read the labels & warnings, do some research to get the MSDS, read the labels, etc., and did I say read the labels?
And last, the new-to-me idea of covering the area with plastic sheeting is a great one, THANKS for passing that along!
Powered by Tinnitus
Parkside Logic - My Site & Blog
sticky interior walls sovereign Upholstery, Blinds, Walls & Interior Finishes 64 08-14-2009 11:18 AM
Zolatone walls Rob Upholstery, Blinds, Walls & Interior Finishes 19 08-05-2009 07:54 PM
Shower walls, what to do? myboyburt General Interior Topics 1 04-16-2004 04:54 PM
getting behind the walls... Chuck General Interior Topics 14 07-11-2002 01:20 PM
