Old 12-21-2008, 06:01 PM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
stripping interior end caps
the interior has been painted with latex paint over the zolatone. Originally posted this question in our thread but no responses so I thought I'd try here.
Since we're about to pull plywood, I was thinking it made sense to strip the upper panels first, so that any residue that got on the floor (soaking through paper etc) would be discarded with the old plywood.
My only concern is the end caps, which are fiberglass. I was planning on using citrastrip to take everything down to either bare metal or to the gel coat. I'm wondering if this product will damage the gel coat of the fiberglass and if so if there is a better product available for these areas. Once this messy task is done I will then start pulling floor sections out.
All lower panels will be stripped in the garage and reinstalled pre-primed ready for the Zolatone system, which I hope to be ready for late summer.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-21-2008, 06:08 PM   #2
Steve.
To be safe, I would suggest sanding or sand blasting the end caps.
If you chance a chemical, you may ruin the end caps, which I am sure you know are not available.
Old 12-21-2008, 06:51 PM   #3
Kevin245's Avatar
Scott,
I'd be concerned about damaging the gelcoat too. If it were me I'd use mechanical means as Andy suggests. Depending on how you intend to refinish you could sand, or blast. I've used baking soda or pulverized pecan shell for delicate materials with good success. As with any untested process/application I'd proceed with caution and test on an inconspicuous area to make sure you get the results you desire.
Good Luck,
Kevin
Eleanor Roosevelt
Old 12-21-2008, 07:12 PM   #4
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
I do not think there is a gel-coat on my prior end-caps.
Maybe I have a different idea of what a "gel-coat" is.
I would also think that a small area (inside the end-cap cabinet perhaps) could be tested with various removers. Also I would think the remover instructions would give info on its use on fiberglass.
We should all be thankful that the damn things are not made of ABS. Or are some of them?
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 12-21-2008, 07:38 PM   #5
Scott, I think it's a great idea to leave the old floors in while you strip the upper panels, ceiling, and endcaps.
As for potential damage to the endcap, others would know better than I would. But I will say that citristrip is a much milder chemical stripper than many others on the market.
Testing somewhere inside the built-in shelf sounds like a very good idea.
Good luck!
Old 12-21-2008, 08:34 PM   #6
goransons's Avatar
1963 22' Safari
Thanks guys.
the 63 doesn't have a built in cabinet, perhaps a small area in wardrobe might work. I think I'll try the sand paper first, see how well a DA does on there tomorrow before I pursue chemical work. Not sure blasting is a good option for me since the interior is coming apart in stages and that would certainly make a huge mess (not that sanding will be a "clean" process.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 12-21-2008, 08:46 PM   #7
kevin barnes's Avatar
1968 26' Overlander
Delta , BC
Images: 36
Napier RemovAll 620 is used to remove paint from fiberglass boats and will not harm gelcoat or fiberglass. It is also environmentally friendly. I have used the 220 to remove paint from aluminum and it works great.
kevin barnes is offline   Reply With Quote
Interior end caps IndyAnne 1959-69 Tradewind 8 09-07-2008 10:17 AM
Cracks in end caps? Anniedog General Interior Topics 8 05-30-2008 09:00 PM
interior plastic end caps catson4 Interior Restoration Forum 1 01-05-2008 06:30 AM
Stripping the Interior End Caps--Am I Nuts? ironfem200 General Interior Topics 2 01-29-2006 04:07 PM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
