06-27-2013, 08:19 AM
2016 30' Flying Cloud
Oviedo
Solution for Securing Bottom of Mini-Blinds
I have been frustrated since almost day 1 with the white plastic clips Airstream uses to secure the bottom of the mini blinds in my Safari SE (now Flying Cloud). I recently fabricated a magnetic catch once I realized the bottom rail of the blind was steel.
I used 1/2" x 1/2" aluminum angle stock (got mine at Lowes - $6 for 8 ft), some 1/4" dia nickel plated neodymium magnets from Amazon, 3M Clear Mounting tape (Walmart) and cyanoacrylate glue to bond the magnets to the aluminum rail (aka super glue). I built these using the basic tools I carry with me while traveling and installed them while staying here at Highland Haven in SW VA (hacksaw, emory cloth, wet/dry sandpaper & Dremel tool) so duplicating these shouldn't be too challenging for most folks.
The rail is attached to the bottom window frame (the mill finish piece that is screwed or riveted to the interior wall using the mounting tape to minimize any more holes in the trailer. If the tape fails to hold up over time, I will use a couple small sheet metal screws per window. The result is a 10" long aluminum rail with 3 small nickel plated magnets on top. The blind height is adjusted so the bottom rail of the blind is held by the magnets. The assemblies blend in with the aluminum window frames and only stick out 1/2" (far less than the window levers).
I will post some photos once I get them uploaded to my Zenfolio site so I can attach them.
The blinds now snap into place and stay put - far less frustration than the stretched-out plastic pieces that were OEM.
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
06-27-2013, 08:51 AM
2010 28' Flying Cloud
Lower Alabama
, USA
Looking forward to more info, they are a PITA.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
06-27-2013, 09:06 AM
Saint Augustine
Can't wait to see the pictures - I have the same frustration with my blinds. Sounds like a great idea that you devised.
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
06-27-2013, 09:11 AM
1972 25' Tradewind
Chattanooga
, Tennessee
Not only a good idea with the blinds, but could work with drapes in older models where the lower rail has disappeared. Thanks.
06-28-2013, 11:25 AM
Oviedo
Photos Added
Keith & Barb
06-28-2013, 01:35 PM
Contributing Member
Austin (Hays County)
A simpler way
I bought rare-earth magnets and matching cups over the net from Rockler. The cup screws into the window frame and the magnet is inserted into the cup. Make darn sure all is right before inserting a magnet, because getting a magnet back out of a cup is tough. The magnets and cups come 10 to a package. The cup I use is on the right on the Rockler page.
I posted a picture of my magnets on this site, but I don't have time to hunt for it right now.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
06-29-2013, 07:59 PM
Saint Augustine
Originally Posted by khollister
Looks great!
WBCCI# 5248
09-12-2013, 06:30 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Great solution khollister. I am going to order some magnets from Amazon to secure the bottom of the cellular blinds I just installed. Thanks for the great design.
Dan
09-12-2013, 06:58 AM
2008 27' Classic FB
Burkburnett
Originally Posted by TouringDan
... I am going to order some magnets from Amazon to secure the bottom of the cellular blinds I just installed. Thanks for the great design ...
I just picked up a 10 pack of these magnets at Harbor Freight for $3. They are about 8mm in diameter, look like hearing aid batteries and are incredibly strong.
AIR 47751
09-12-2013, 08:46 AM
1974 Argosy 20
Kooskia
, Idaho
I just used a piece of angle steel rather than aluminum. Mine is only about 3" long, centered in the window, and the magnets stick to the steel as well as the bottom of the blind. No glue required. I used the original screws that hold the trim in place for the angle metal, so not even new holes were required. I also used the Harbor Freight magnets, which work fine. I put 3 on each piece of steel.
09-13-2013, 01:26 PM
1986 32' Excella
Canton
, Georgia
Brilliant!
09-13-2013, 02:02 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
I just did the same thing. I tried using the magnetic tape; it is not strong enough. There is a HF here, headed out to get the magnets.
07-31-2014, 07:53 AM
2008 23' Safari FB SE
Boulder
Interesting that they stick without glue. I was concerned about the L bracket since we lean against our windows in the dinette. This seems to imply I could put the magnets without glue on my window frame and then press the blind against it without the L bracket. Do y'all think this would work?
If so, simple and elegant solution that requires no drilling or glue.
12-02-2014, 10:38 PM
2007 25' Safari SS SE
Davis
When we bought our 2007 Safari last Christmas we were to have had new metal hold down clips for the blinds installed from the dealer to replace the already broken one or two we spotted. Needless to say they didn't install anything. (Can I simply suggest to stay away from Southwest Coaches in Riverside, CA---or is this notation not allowed?)
I found at "http://blindsusainc.com/blindsusa-hold.htm#holddowns",
the metal Hold Down Brackets Item# HD-1NZP , (pair): $2.45.
These are shiny metal, the vendor states Zinc but it looks chromed or polished stainless. And they could not fit any more perfect than they do.
If you want magnets, go for it, but we are thrilled to have these metal hold down clips.
12-03-2014, 05:40 AM
2019 23' International
La Habra
Do you have any pictures? I'd like to replace our plastic tabs as well
2019 GMC Sierra Denali
2019 23CB International
12-03-2014, 10:36 PM
Davis
Sorry, at the moment I don't have pictures of my own, but....
if 'blindsusainc.com' forgives me for stealing their picture from the link I provided, it shows you the vendor's picture -including a ruler showing the size of the clips.
12-04-2014, 06:52 AM
La Habra
Thanks, I found their site
