Old 08-15-2011, 07:19 PM   #1
tr0y's Avatar
Las Vegas , Nevada
Smooth interior walls /hiding rivets
Hi All -
I am new here and looking for your expertise...
I was wondering if anyone had ground down and smoothed out interior walls to hide rivets to give the interior walls a totally smooth look ? I was thinking grind them down a bit and then feather in Bondo or a similar material like you would with drywall mud to hide the fasteners. Am I crazy ? Any thoughts ?
I did some searching in the forums but did not find anything.
Troy
tr0y is offline   Reply With Quote
Old 08-15-2011, 08:01 PM   #2
1977 Argosy 24
Milltown , Wisconsin
If you grind them it will compromise their strength. If you cover them with body filler they do move a little with temperature changes and road vibration. I think you would see them after a few trips down one of our fine worn out highways.
ventport is offline   Reply With Quote
Old 08-15-2011, 08:11 PM   #3
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Originally Posted by tr0y
Hi All -
Troy
Rivets are cool!
Phrunes is offline   Reply With Quote
Old 08-15-2011, 08:32 PM   #4
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
You can get some types of vinal / pleather upholstery material that has a 1/8 or thicker foam backer. When you glue this in as a wall covering it will for the most part make the rivet heads disappear
Darkspeed is offline   Reply With Quote
Old 08-15-2011, 11:27 PM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Rivet grinding
Originally Posted by tr0y View Post
Hi All -
Troy
Troy, Don't grind them as your interior panels wil POP (pun intended) off the wall segment ribs and you will do a lot of harm that will be a pita to repair! If you can't stand the look of them the only real choice is to place an interior covering over the entire exposed interior and that would be difficult at best. Get used to them and make them your friends. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-15-2011, 11:29 PM   #6
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
What he's trying to say is treat rivets like your in-laws.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 08-16-2011, 12:34 AM   #7
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
what a riveting idea.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 08-16-2011, 06:56 AM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Use flush rivets
Old 08-16-2011, 07:39 AM   #9
one of those
Gringo's Avatar
hmm...how many would you have to drill out and replace?
don't the true flush riveting jobs like on aircraft wings, require a corresponding dimple in the skin? which would mean you need access to both sides, right?
Old 08-16-2011, 08:41 AM   #10
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Very bad idea. The first road trip will (if you get that far) will result in some unintended consequences...your interior walls will separate from the structure and you will have a major mess on your hands.
Living life on the Road
deauxrite is offline   Reply With Quote
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 09:01 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 11:49 AM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
