Old 03-23-2013, 11:11 AM   #1
mddogpilot's Avatar
2011 25' FB Flying Cloud
Fox Island , Washington
Sliding cabinet doors CCD
Opaque cabinet door covers are worn and ugly. Anyone found replacements? 04 CCD
mddogpilot is offline   Reply With Quote
Old 03-23-2013, 11:24 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
You could order new ones but I bet you could find something local to copy yours.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 03-24-2013, 12:15 PM   #3
Ramble On's Avatar
2004 28' International CCD
rockwall , Texas
I own a 2004 International 28', mine are wore and ugly too. I removed the sliding doors and sanded the back side using an orbital sander and 100 grit sandpaper. It improved the appearance, but I still want to replace. I've looked into using Lumicor as a replacement, but seems to be expensive.
Ramble On is offline   Reply With Quote
Old 03-24-2013, 12:32 PM   #4
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
Any decent cabinet shop should be able to make replacement doors for you.
I own a custom shop and would be able to do it but I'm in Va.
tarnished is offline   Reply With Quote
Old 03-25-2013, 11:18 AM   #5
mddogpilot's Avatar
Thanks. I'll see if I can get a local cabinet shop to make them out of lumicor
Old 03-25-2013, 01:47 PM   #6
Ramble On's Avatar
rockwall , Texas
All you need is a table saw and hole saw or forstner bit. The dimension are listed in the parts manual.
