Old 11-11-2014, 09:33 AM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Shower seating
My shower has a large built in seat. It seems a waste of interior space. Does any one know if anything is located within the hump?
MICHAEL
Old 11-11-2014, 10:37 AM   #2
dznf0g's Avatar
Oswego , Illinois
In my case, the wheel well is under it...but you're on a corner. So if there are no outside connectors there, like water, electrical, etc. it should be hollow.
-Rich-
Old 11-11-2014, 10:41 AM   #3
2002 19' Bambi
Lafayette , California
If it is like my 2002 19' Bambi (which looks identical), there is nothing but some wiring in that space. I added a large screw-in deck plate (like this: BECKSON MARINE 8" Smooth Screw-In Deck Plate, 10-1/8" Flange, 8-1/2" Cutout, Black/Clear | West Marine ) to a vertical face of the hump (the one that faces left in your picture). Installed carefully, the plate is waterproof and gives access to what is, otherwise, empty.
Tim
Tim A. is offline   Reply With Quote
Old 11-11-2014, 11:26 AM   #4
2005 19' Safari
GLENDALE , AZ
Just curious, what would one store in this location? It seems like with a 10" opening, size might be a restriction. Also, items less than 10" wide (or in diameter) might move around and get lost, or be difficult to retrieve.
Don't mean to sound negative; I'm just trying to figure out how this unused storage area could best be used...
Old 11-11-2014, 12:38 PM   #5
2002 19' Bambi
We often have our heavy hiking boots there. My wife's go in easily, mine scrape a bit. Guess who has the bigger feet.
Adding the access is just one of many ways I have expanded storage in our little trailer. Has adding the deck plate made a great difference? No, other than also giving me a way to check on any leakage.
Tim
Old 11-12-2014, 07:42 AM   #6
AWCHIEF's Avatar
Images: 33
Anything that will fit. A stubby AR and a thousand rounds of ammo, emergency rations and your basic anti-zombi kit should all fit just fine. I just happen to have a couple of locking marine hatches left over from a build. I think one of them will fit just fine. They are 12X8, waterproof and lockable.
MICHAEL
seating a one-piece back tank/potty/shower combo Aktundra Sinks, Showers & Toilets 2 05-27-2012 12:14 AM
1962 Tradewind front seating plan? retrocats General Interior Topics 1 03-07-2007 12:33 AM
first try for new front seating remcolent General Interior Topics 2 11-27-2006 08:59 AM
Photo of Booth Seating Orland Dewey Classic Motorhomes 10 05-16-2005 09:14 AM
Question on Fabric for seating nbka1bm Upholstery, Blinds, Walls & Interior Finishes 5 04-07-2004 09:04 AM
