Old 02-02-2014, 04:27 AM   #1
GaŽl's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
Shelves fixations
Hello everybody,
I wish to know how are fixed shelves to the walls please ?
Exist it several manners to fix them ?
Thank you and have a good sunday
1960 Overlander
2002 Chevrolet Tahoe
GaŽl is offline   Reply With Quote
Old 02-02-2014, 07:13 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Gael,
It may depend on the model. Most shelves are not directly attached to walls but to cabinets and closets which are then attached to the wall. The exception is the overhead lockers. Anything attached to the walls should be riveted with blind rivets (pop rivets), and if possible to a rib or stringer under the interior skin.
Old 02-02-2014, 07:22 AM   #3
Central , Mississippi
On my '63, almost everything was attached with flat head wood screws thru the cabinets/dividers/lockers and into the aluminum walls. Some of these had wooden plugs covering the screw head to hide it.
It is a real hide-and-seak game to find them all.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-02-2014, 08:19 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
These are used
You can use these for wall dividers and shelves. Very hard to apply to a curved wall....the old Airstreams gad them made with aluminum which would bend to wall contours easily. Maybe in France you can find something similar.Bulkhead Moulding
Old 02-02-2014, 10:42 AM   #5
GaŽl's Avatar
1960 26' Overlander
Images: 8
Thank you very much for your replies !
I have to build the interior myself and I think I have to fix each shelf with each near woodwall, yes you're reason, so it's what I thought...
The problem is for the overheads lockers... hummmm... how are fixed these ? have you foto too ?
Many many thanks for your help...
1960 Overlander
Old 02-02-2014, 04:14 PM   #6
Originally Posted by GaŽl View Post
Thank you very much for your replies !...
Screws straight up into the roof thru the top front wooden piece, straight into the wall thru the rear bottom wooden piece.
Old 02-10-2014, 01:47 AM   #7
GaŽl's Avatar
1960 26' Overlander
Images: 8
Ah ok, I look on my Airstream and I tell you !
Thanks !
1960 Overlander
Favorite Mod Under $100 Roscinante General Repair Forum 548 08-11-2016 04:43 AM
Pull out Pantry with adjustable shelves batman Cabinets, Counter Tops & Furnishings 9 07-15-2014 05:38 AM
Dometic RM 3804 fridge door shelf rollin home Refrigerators 6 08-16-2012 07:19 PM
shelves scubadog 2009-2015 Flying Cloud 1 02-08-2012 03:38 PM
Adding shelves to roof lockers. Forger Cabinets, Counter Tops & Furnishings 13 07-26-2011 09:07 PM
